Meteohub transmitted two sets of data
ingogliar
Post by ingogliar »
May I ask for someone's help with this matter?
My Meteohub (Sheevaplug from Rainman Weather) is, according to Mr. Gladstone, transmitting two different sets of pressure readings - one with the luminosity reading, the other without it:
20120923210207,DW8219>APRS,TCPXX*,qAX,CWOP-2:@232102z4051.37N/07405.07W_311/003g010t066r000p037P000b10164h42L315eMH49
20120923211707,DW8219>APRS,TCPXX*,qAX,CWOP-3:@232117z4051.37N/07405.07W_256/003g009t066r000p037P000b10164h41L047eMH49
20120923211714,DW8219>APRS,TCPXX*,qAX,CWOP-2:@232117z4051.37N/07405.07W_256/003g009t066r000p037P000b10164h41eMH49
20120924014209,DW8219>APRS,TCPXX*,qAX,CWOP-3:@240142z4051.37N/07405.07W_311/000g002t056r000p011P000b10125h70L000eMH49
20120924014215,DW8219>APRS,TCPXX*,qAX,CWOP-2:@240142z4051.37N/07405.07W_311/000g002t056r000p011P000b10185h70eMH49
20120924014708,DW8219>APRS,TCPXX*,qAX,CWOP-3:@240147z4051.37N/07405.07W_311/000g000t056r000p004P000b10124h70L000eMH49
20120924014715,DW8219>APRS,TCPXX*,qAX,CWOP-3:@240147z4051.37N/07405.07W_311/000g000t056r000p004P000b10184h70eMH49
20120924015208,DW8219>APRS,TCPXX*,qAX,CWOP-2:@240152z4051.37N/07405.07W_311/000g000t056r000p004P000b10125h71L000eMH49
20120924015215,DW8219>APRS,TCPXX*,qAX,CWOP-2:@240152z4051.37N/07405.07W_311/000g000t056r000p004P000b10185h71eMH49
The problem apparently started between 21:17Z on 23rd Sept and 0142Z on the 24th.
Can someone help me figure out what is going on - I would be most appreciative.
Thank you.
Re: Meteohub transmitted two sets of data
New versions of Meteohub do add the L-data into the packets and do send pressure as altimeter.
Looks like two meteohubs are sending with different sw versions.
Are you using meteoplug service in addition and do you have CWOP selected there as weather network as well?
