No option for taking wind chill rates from the station
panos1981
Post by panos1981 »
I run Meteohub's latest version (4.9q). The problem is that in the "Weather Station" panel there is no option for taking wind chill rates directly from weather station. It provides only the option "compute from wind and temperature readings". What can I do to fix this?
PS: The station in use is LaCrosse WS2300.
Thank you!
Re: No option for taking wind chill rates from the station
What is wrong with computing it from temp/hum and wind in Meteohub?
panos1981
Post by panos1981 »
The problem is that the wind chill rates of the station are not always the same with the Meteohub's wind calculation. Most times the weather station's wind chill rates are lower than Meteohub's rates, so I wonder which are the correct and more accurate. This difference becomes because of the type that is used for the wind chill calculation or for some other reason?
