Recently I mentioned that Meteohub everyday records for two or three minutes very high temperature readings (e.g. 80,2 c degrees) and then returns to normal records. What might be the problem? Is it about the connection type with the weather station (serial- serial USB) or has to do with any problem of the sensor? I would really appreciate any idea or help, because doing everyday recomputation of weather data (after deleting the wrong records) is very annoying....
Thank you!
P.S.: I use the LaCrosse WS2300
Bug report: Very high temperature records
