Errors in log files after Meteohub 4.9r was installed
jeanandgino
Post by jeanandgino »
Hi Everyone,
Got my new Weatherhub 4 up and running last Saturday. There were no errors in the log files. On Sunday, I checked for updates and it found 4.9r. So I installed it, since then, more times than not it would not be able to gather data from my Vantage Pro 2. I would reboot it and it would work for a couple of hours then stop. Tonight, I checked for updates and once again it found 4.9r, so I installed it again. I am getting fewer errors (the alarm log is now clean), but I still getting errors. To soon to tell if it will stay up and running but this is what I see in the logs. Any help or insights would be great.......if not then I will return it to the vendor I purchased it from.
System Log:
012.12.20 17:26:58 log file cleared by user
2012-12-20T17:30:31.013688-08:00 meteohub rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c4 as the first rsyslogd option.
2012-12-20T17:30:31.020054-08:00 meteohub rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2012-12-20T17:30:31.021772-08:00 meteohub rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2012-12-20T17:30:31.021844-08:00 meteohub rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
2012-12-20T17:36:22.429072-08:00 meteohub rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c4 as the first rsyslogd option.
2012-12-20T17:36:22.435472-08:00 meteohub rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2012-12-20T17:36:22.437193-08:00 meteohub rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2012-12-20T17:36:22.437264-08:00 meteohub rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
smb server log:
2012.12.20 17:27:08 log file cleared by user
[2012/12/20 17:30:06.195396, 1] param/loadparm.c:6494(map_parameter)
Unknown parameter encountered: "disable poolss"
[2012/12/20 17:30:06.197669, 0] param/loadparm.c:7588(lp_do_parameter)
Ignoring unknown parameter "disable poolss"
[2012/12/20 17:35:57.538660, 1] param/loadparm.c:6494(map_parameter)
[2012/12/20 17:35:57.539503, 0] param/loadparm.c:7588(lp_do_parameter)
ntp client log:
2012.12.20 17:27:13 log file cleared by user
20 Dec 17:30:43 ntpd[899]: ntpd exiting on signal 15
20 Dec 17:33:37 ntpd[1325]: ntpd exiting on signal 15
20 Dec 17:36:23 ntpd[1091]: Deferring DNS for 0.pool.ntp.org 1
20 Dec 17:36:23 ntpd[1091]: Deferring DNS for 1.pool.ntp.org 1
20 Dec 17:36:23 ntpd[1406]: signal_no_reset: signal 17 had flags 4000000
20 Dec 17:36:24 ntpd[1091]: Deleting interface #4 eth0:0, 192.168.1.77#123, interface stats: received=0, sent=0, dropped=0, active_time=1 secs
20 Dec 17:36:24 ntpd[1091]: Deleting interface #3 eth0, 192.168.1.142#123, interface stats: received=0, sent=0, dropped=0, active_time=1 secs
20 Dec 17:36:25 ntpd[1406]: host name not found: 0.pool.ntp.org
20 Dec 17:36:25 ntpd[1406]: host name not found: 1.pool.ntp.org
20 Dec 17:36:35 ntpd[1091]: ntpd exiting on signal 15
20 Dec 17:36:55 ntpd[1406]: parent died before we finished, exiting
jeanandgino
Re: Errors in log files after Meteohub 4.9r was installed
After less than 50 minutes it has stopped retrieving data and the Alarm log has the following message:
2012.12.20 17:26:52 log file cleared by user
2012.12.20 18:12:05 meteohub: weathernet: No data upload to weather networks as sensor selected on weather network page for outdoor temp, outdoor humidity or outdoor dewpoint is not providing recent data.:
meteohub log:
ogger (20.12.2012 18:01:47): child process received timeout signal (14).
logger (20.12.2012 18:02:27): disconnect station 0 (Vantage).
logger (20.12.2012 18:02:28): data logger stopped.
logger (20.12.2012 18:02:29): data logger (version 4.9r, build 1204) started.
logger (20.12.2012 18:02:40): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:03:11): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:03:11): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:03:41): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:04:11): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:04:12): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:04:42): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:05:12): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:05:12): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:05:45): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:06:16): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:06:16): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:06:46): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:07:16): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:07:16): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:07:46): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:08:16): child process received timeout signal (14).
logger (20.12.2012 18:08:17): data logger stopped.
logger (20.12.2012 18:08:18): data logger (version 4.9r, build 1204) started.
logger (20.12.2012 18:08:28): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:08:59): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:09:31): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:10:01): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:10:31): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:11:01): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:11:31): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:12:01): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:12:31): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:13:01): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:13:31): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:14:01): child process received timeout signal (14).
logger (20.12.2012 18:14:02): data logger stopped.
logger (20.12.2012 18:14:03): data logger (version 4.9r, build 1204) started.
logger (20.12.2012 18:14:14): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:14:44): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:15:16): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:15:16): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:15:17): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:15:47): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:16:17): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:16:17): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:16:47): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:17:17): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:17:17): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:17:47): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:18:21): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:18:21): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:18:51): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:19:21): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:19:21): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:19:51): child process received timeout signal (14).
logger (20.12.2012 18:19:51): data logger stopped.
logger (20.12.2012 18:19:53): data logger (version 4.9r, build 1204) started.
logger (20.12.2012 18:20:03): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:20:36): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:21:06): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:21:06): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:21:36): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:22:06): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:22:06): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:22:36): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:23:06): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:23:06): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:23:36): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:24:06): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:24:06): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:24:36): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:25:06): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:25:06): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:25:36): child process received timeout signal (14).
logger (20.12.2012 18:25:37): data logger stopped.
logger (20.12.2012 18:25:38): data logger (version 4.9r, build 1204) started.
logger (20.12.2012 18:25:49): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:26:21): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:26:21): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:26:51): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:27:21): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:27:21): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:27:51): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:28:21): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:28:21): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:28:51): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:29:21): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:29:21): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:29:52): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:30:22): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:30:22): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:30:52): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:31:26): child process received timeout signal (14).
logger (20.12.2012 18:31:26): data logger stopped.
logger (20.12.2012 18:31:28): data logger (version 4.9r, build 1204) started.
logger (20.12.2012 18:31:38): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:32:09): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:32:09): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:32:10): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:32:41): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:33:11): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:33:11): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:33:45): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:34:16): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:34:16): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:34:46): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:35:16): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:35:16): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:35:46): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:36:16): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:36:16): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:36:46): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:37:16): child process received timeout signal (14).
logger (20.12.2012 18:37:17): data logger stopped.
logger (20.12.2012 18:37:18): data logger (version 4.9r, build 1204) started.
logger (20.12.2012 18:37:29): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:38:00): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:38:31): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:39:01): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:39:31): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:40:01): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:40:31): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:41:01): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:41:31): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:42:01): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:42:32): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:43:02): child process received timeout signal (14).
logger (20.12.2012 18:43:02): data logger stopped.
logger (20.12.2012 18:43:04): data logger (version 4.9r, build 1204) started.
logger (20.12.2012 18:43:14): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:43:44): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:44:17): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:44:17): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:44:47): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:45:21): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:45:21): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:45:51): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:46:21): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:46:21): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:46:51): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:47:21): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:47:21): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:47:51): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:48:21): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:48:21): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:48:51): child process received timeout signal (14).
logger (20.12.2012 18:48:52): data logger stopped.
logger (20.12.2012 18:48:53): data logger (version 4.9r, build 1204) started.
logger (20.12.2012 18:49:03): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:49:36): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:50:06): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
logger (20.12.2012 18:50:06): error while doing write on socket 5558: Broken pipe
logger (20.12.2012 18:50:36): station 0 (Vantage), can't open device /dev/ttyUSB0: Protocol error
you are not using the neceaary USB 2.0 hub inbetween your weather station and hte DC01.
