Template not replacing variables
mattbrailsford
Post by mattbrailsford »
I have a template that I upload to my server on a regular basis which has been working fine for ages, however recently it has started having issues. The uploaded file doesn't always get it's placeholder variables replaced.
I have recently upgraded the software so I'm wondering if this might be the issue. Has anyone else experienced this?
Re: Template not replacing variables
when there is no data avail for the variable you request in the template, the template stays as is, unlike you use ":" notation to stae what should be printed out instead. Manual expalins how to use these directives.
missing sensor data is more likely to happen in cold, dark winter, when batteries in sensors go down in capacity.
