The problem is that meteohub starts to error on the data it's receiving from my WGR800, shortly after the logger process has started. The log messages look like this:
I know it's not a problem with the WGR800, as the console continues to receive data without issue, and also if i restart logging again, it often corrects the problem (or sometimes it fixes itself after a few hours).logger (09.01.2013 22:59:11): Bad wind5636639(56021f) sensor data, "chill x10" (758145640) out of range [-700:1500]
logger (09.01.2013 22:59:25): Bad wind5636639(56021f) sensor data, "chill x10" (758145640) out of range [-700:1500]
logger (09.01.2013 22:59:39): Bad wind5636639(56021f) sensor data, "chill x10" (758145640) out of range [-700:1500]
logger (09.01.2013 22:59:53): Bad wind5636639(56021f) sensor data, "chill x10" (758145640) out of range [-700:1500]
logger (09.01.2013 23:00:07): Bad wind5636639(56021f) sensor data, "chill x10" (758145640) out of range [-700:1500]
logger (09.01.2013 23:00:21): Bad wind5636639(56021f) sensor data, "chill x10" (758145640) out of range [-700:1500]
logger (09.01.2013 23:00:35): Bad wind5636639(56021f) sensor data, "chill x10" (758145640) out of range [-700:1500]
logger (09.01.2013 23:00:49): Bad wind5636639(56021f) sensor data, "chill x10" (758145640) out of range [-700:1500]
logger (09.01.2013 23:01:03): Bad wind5636639(56021f) sensor data, "chill x10" (758145640) out of range [-700:1500]
I'm not sure if this problem is connected in any way with the problem I previously reported about the battery low warning, which is still ongoing.
Any thoughts most appreciated!!
Cheers
