wmr88 anemometer problems and meteohub
somiedo
Post by somiedo »
Hello, I have a problem with my station and meteohub wmr88 oregon.
When I install wmr88 with meteohub station, I automatically detects all sensors of the station, except the anemometer.
On the LCD console oregon station if there anemometer data reading, but not detected meteohub anemometer. But it recognizes the remaining external temperature sensors, internal moisture, etc.. What I can do to get meteohub recognize the anemometer.? The anemometer may be faulty, but if it works on lcd wmr88 is a sign that it is not broken, right?
I restarted, resetting meteohub, all sensors and weather station, but nothing changes. Still not working the anemometer.
Can you help me? thank you very much!
somiedo
somiedo
Re: wmr88 anemometer problems and meteohub
Post by somiedo »
Hello again, I tried again with oregon wmr88 meteohub turn and still not recognized automatically WRG800 anemometer sensor. Rule that is broken, because using software os oregon weather, the anemometer itself that sends data to the program and I have wind readings. What I can do? thank you very much.
pd: excuseme for my bad English, I'm Spanish sorry ..
markhiseman
Post by markhiseman »
Somiedo. It might be the same problem I had here: viewtopic.php?f=14&t=8873&start=30
I reverted to buld 4.9e, and its been OK since. I don't know if that is an option any more?
please go to "weather station" page and press "save". This stores some changes done
behind the scenes in regard to wind chill calculations. newest version "4.9t" should
work fine with wmr88.
