Update 4.9t
What's hot...
Update 4.9t
Update to Meteohub V4.9t (NSLU2, x86, SheevaPlug, DreamPlug, iConnect, DC01, mini X) brings these features:
  • fixes a data logging issue with stations WH-1080, WH-2080, etc from Fine Offset.
Update Link: http://www.meteohub.de/files/update-v4.9t.upd
Amortalis
Re: Update 4.9t
Post by Amortalis »
4.9t installed a few days ago (about 2) today I was checking for updates and got the message "downloading 4.9t" and now I have the "ready to install 4.9t" message. Is there a install endless loop like that one from the prior version?
cbhiii
Re: Update 4.9t
Post by cbhiii »
Can you confirm that the emailing process for alarms is not functioning? I cannot send myself a test email. I have not changed any settings. I now see these errors in the system log when emails should go out:
Jan 27 23:55:16 meteohub kernel: sendmail[21080]: segfault at 00000000 eip 00000000 esp bff2b6ec error 4
Jan 27 23:58:50 meteohub kernel: sendmail[21344]: segfault at 00000000 eip 00000000 esp bfac2a9c error 4
Jan 28 23:55:15 meteohub kernel: sendmail[18774]: segfault at 00000000 eip 00000000 esp bff5c0cc error 4
Jan 28 23:58:51 meteohub kernel: sendmail[19050]: segfault at 00000000 eip 00000000 esp bfb03adc error 4
Jan 29 22:53:57 meteohub kernel: sendmail[15487]: segfault at 00000000 eip 00000000 esp bf8324dc error 4
Jan 29 22:54:42 meteohub kernel: sendmail[15696]: segfault at 00000000 eip 00000000 esp bfd6958c error 4
Jan 29 22:56:53 meteohub kernel: sendmail[15958]: segfault at 00000000 eip 00000000 esp bfbf089c error 4
YJB
Re: Update 4.9t
Post by YJB »
I'm not seeing that issue here on virtualbox (4.9t Build 6891). My alix1D (before I switched) did send out emails as well.
Does sending out a testmail (setup push services) fail as well?
wfpost
Re: Update 4.9t
Post by wfpost »
look at my post 4 weeks ago
viewtopic.php?f=14&t=9122&start=15
Boris,
anything you can check, why email is broken now ??
I don´t want to go back to 4.9q
Re: Update 4.9s
Postby wfpost » 04 Jan 2013 00:22
just realized, that email stopped after updating to version 4.9r
Always getting segfault errors, even with the testmail function
just updated to 4.9s, but still the error with not sending emails
Jan 4 00:15:20 meteohub kernel: sendmail[3263]: segfault at 00000000 eip 00000000 esp bfa8acac error
Dec 30 09:00:42 meteohub kernel: sendmail[13089]: segfault at 00000000 eip 00000000 esp bfb1935c error 4
Dec 30 23:55:10 meteohub kernel: sendmail[26211]: segfault at 00000000 eip 00000000 esp bf8b853c error 4
Dec 30 23:59:41 meteohub kernel: sendmail[26833]: segfault at 00000000 eip 00000000 esp bfc7a0dc error 4
Dec 30 23:59:45 meteohub kernel: sendmail[26844]: segfault at 00000000 eip 00000000 esp bfc372ec error 4
Dec 31 09:00:47 meteohub kernel: sendmail[31099]: segfault at 00000000 eip 00000000 esp bfa6327c error 4
Dec 31 23:55:03 meteohub kernel: sendmail[8773]: segfault at 00000000 eip 00000000 esp bfd8532c error 4
Dec 31 23:55:04 meteohub kernel: sendmail[8782]: segfault at 00000000 eip 00000000 esp bfc676bc error 4
Dec 31 23:55:05 meteohub kernel: sendmail[8785]: segfault at 00000000 eip 00000000 esp bff3636c error 4
Dec 31 23:57:02 meteohub kernel: sendmail[9070]: segfault at 00000000 eip 00000000 esp bfc956fc error 4
Dec 31 23:57:03 meteohub kernel: sendmail[9078]: segfault at 00000000 eip 00000000 esp bf9e723c error 4
Dec 31 23:59:42 meteohub kernel: sendmail[9402]: segfault at 00000000 eip 00000000 esp bfb6312c error 4
Jan 4 00:06:59 meteohub kernel: sendmail[10558]: segfault at 00000000 eip 00000000 esp bfbc96bc error 4
cbhiii
Re: Update 4.9t
Post by cbhiii »
Thanks wfpost. I've been a little out of touch and missed that. Appreciate you confirming it.
wfpost wrote:look at my post 4 weeks ago
bottkars
Re: Update 4.9t
Post by bottkars »
Amortalis wrote:4.9t installed a few days ago (about 2) today I was checking for updates and got the message "downloading 4.9t" and now I have the "ready to install 4.9t" message. Is there a install endless loop like that one from the prior version?
Any feedback on that ? Having the same issue on iconnect
http://www.bottnet.de
Wetterstation Oregon Scientific WMR200
Meteohub on iconnect
Re: Update 4.9t
don't worry, just ignore.
Chill
Re: Update 4.9t
Post by Chill »
Installed 4.9t give me problems with Windchill readings from Oregon WMR200 station.
The only way it works is forcing to calculate from temp & wind values rather than using the station output.
Chill
