Update Meteobridge 1.2
Application SW stack in version 1.2 has been released.
When you do a reboot/power cycle Meteobridge will load this new version.
Improvements of 1.2 are:
  • adds signal strength to SSID drop-down list
  • fixes a configuration bug that prevents from reading data from WS2300 type stations
  • fxing a bug uploading average windspeed to previmeteo
  • reduce timeout for mysql connection setup to 6 seconds
  • moving static reserve LAN IP from 192.168.1.111 to 192.168.168.111 to avoid routing conficts with typical user class c networks when switching to wlan
  • removing evapotranspiration values (which did appear randomly) from solar sensor data, if not Vantage station.
  • adding a display that shows how much of internal data send buffer is currently occupied (system tab)
  • reducing memory footprint of data send process to avoid triggering oom linux mechanisms
  • doing a reboot in case of oom situations by issueing a kernel panic instead of trying to stop some applications via oom_killer.
  • added support for generation of wind direction strings in German (dedir) and English (endir) within templates.
