Only a blinking led after flash
Just did a Flash of Meteobridge Firmware to TL-MR3020
All went well until after the TP-Link screen read "rebooting device etc.".
The TL-MR3020 started blinking with the largest led (wps) slowly until after a few minutes it was suddenly blinking very fast.
As I understand the documentation it is trying to load the meteobridge stack.
Nothing happens, only blinking.
The TL-MR3020 is connected to the LAN directly, no address in the network is seen for this device.
Emergency ip address of 192.168.1.111 (version 1.1) is not found when scanning.
The only "non-normal" aspect of my setup is that there is another meteobridge (Asus) on the network which is fully operational.
Thanks for looking into it.
Wim van der Kuil
http://www.wiri.be
Re: Only a blinking led after flash
Solved.
Connected the TL-MR3020 directly to the internet and the blinking went differently.
After a few moments of rapid blinking more than 1 led cam one.
I removed the device from the internet modem and put it after the router and now it is visible from within my local network. Everything works now and I can login to Meteobridge.
So now i can start testing it with different weatherstations.
Wim van der Kuil
www.wiri.be my meteobridge template
