Update 4.9u
What's hot...
Update 4.9u
Update to Meteohub V4.9u (NSLU2, x86, SheevaPlug, DreamPlug, iConnect, DC01, mini X) brings these features:
  • updates demo/trial period to end of October 2013
  • fixes virtual sensor bug on DC01
  • fixes bug with HV inputs on LabJack U3 HV
  • fixes a burg reading data from ws888, ws550 and alike stations
  • adds FTP upload of a days data in WSWIN format. Sensors used for upload are controlled by settings on WSWIN page. Tags to select a days upload are "wswin-today" and "wswin-yesterday"
  • when doing graph upload a "*" in front of target file name indicates that yesterdays timestamp shold be used when referencing date variables in "strftime" format string. Example: Given the date 30-03-2013 a string "%Y%m%d.csv" will result in filename "20130330", while "*%Y%m%d.csv" will result in filename "20130329".
  • Vantage LOOP2 support should fix barometer deviations between Meteohub and Davis console.
Update Link: http://www.meteohub.de/files/update-v4.9u.upd
cgn
Re: Update 4.9u
Post by cgn »
admin wrote:[*] adds FTP upload of a days data in WSWIN format. Sensors used for upload are controlled by settings on WSWIN page. Tags to select a days upload are "wswin-today" and "wswin-yesterday"
[*] when doing graph upload a "*" in front of target file name indicates that yesterdays timestamp shold be used when referencing date variables in "strftime" format string. Example: Given the date 30-03-2013 a string "%Y%m%d.csv" will result in filename "20130330", while "*%Y%m%d.csv" will result in filename "20130329".
This seems to be a nice feature.
I have updated to 4.9u and tried this feature but it doesn't work.
In "WSWin data export" I had selected the sensors.
Schedule is "every hour", filenames are "today.csv" and "yesterday.csv".
"Generate WSWIN data ongoing" is on (is this required?)
But both (wswin-today and wswin-yesterday) are not uploaded (other files do).
And they aren't in the folder myweb/uploads.
Are there any other settings required?
reicharb
Re: Update 4.9u
Post by reicharb »
I had a probem with this update on my DC01 and Davis weather station. After I upgraded I could not get any sensor data. I have to install 4.9t and I started recieving data again. Has anyone else seen this problem?
Re: Update 4.9u
What kind of Davis station and data logger (serial, usb, tcpip) do you have?
Could you please post "meteohub log" results from "Log Files" page?
Re: Update 4.9u
WSWIN daily export feature still has a bug on certain platforms, will be fixed soon.
reicharb
Re: Update 4.9u
Post by reicharb »
I am setup to use both usb and IP. neither would work.
I emailed the log file to your info@meteohub.de e-mail address. I had trouble attaching.
Re: Update 4.9u
I uploaded a hot fix for the bug related to WSWIN daily data upload.
Please install 4.9u again and after that press "save" on "graph upload"
page in order to apply changes to the upload definition in crontab.
cgn
Re: Update 4.9u
Post by cgn »
"WSWIN-today" works now, but "WSWIN-yesterday" doesn't. :(
Re: Update 4.9u
sorry, a quote was missing. :roll:
This is fixed now, please "re-update" to 4.9u and press "save" on "graph upload" page.
cgn
Re: Update 4.9u
Post by cgn »
Now "WSWIN-yesterday" works too.
Thank you for the quick hotfix. :D
meteo-quimper
Re: Update 4.9u
Post by meteo-quimper »
Hi Boris
There is another bug with the pressure sensor (Vantage Pro 2) with the update 4.9U (6929,6933):
The data on the graphs are ok for the pressure, but not with the tags...
The bug disapear when i came back to 4.9T
awekas
Re: Update 4.9u
Post by awekas »
Can someone confirm WSWIN month file creation did not work? if i click on generate wswin month file the message "file creation initiated" was shown but no file in export directory was generated.
On my box no problems with VP2 indoor sensor.
wfpost
Re: Update 4.9u
Post by wfpost »
yes, I can confirm this
wswin creation is dead
seems the tmp file creation starts and creates the file, but it then is not written into the correct monthly file
.wswin-201304.tmp
cgn
Re: Update 4.9u
Post by cgn »
I can confirm this, too.
awekas
Re: Update 4.9u
Post by awekas »
Boris has now fixed the bug. If you update box once more WSWIN export works well. (no new build number)
currently build 4.9u (Build 6933)
I confirm export works well now.
Othmar
