Page 1 of 4
Update 4.9u
Posted: Sat Apr 13, 2013 3:40 pm
Update to Meteohub V4.9u (NSLU2, x86, SheevaPlug, DreamPlug, iConnect, DC01, mini X) brings these features:
  • updates demo/trial period to end of October 2013
  • fixes virtual sensor bug on DC01
  • fixes bug with HV inputs on LabJack U3 HV
  • fixes a burg reading data from ws888, ws550 and alike stations
  • adds FTP upload of a days data in WSWIN format. Sensors used for upload are controlled by settings on WSWIN page. Tags to select a days upload are "wswin-today" and "wswin-yesterday"
  • when doing graph upload a "*" in front of target file name indicates that yesterdays timestamp shold be used when referencing date variables in "strftime" format string. Example: Given the date 30-03-2013 a string "%Y%m%d.csv" will result in filename "20130330", while "*%Y%m%d.csv" will result in filename "20130329".
  • Vantage LOOP2 support should fix barometer deviations between Meteohub and Davis console.
Update Link: http://www.meteohub.de/files/update-v4.9u.upd
Re: Update 4.9u
Posted: Wed Apr 17, 2013 8:33 pm
by cgn
admin wrote:[*] adds FTP upload of a days data in WSWIN format. Sensors used for upload are controlled by settings on WSWIN page. Tags to select a days upload are "wswin-today" and "wswin-yesterday"
[*] when doing graph upload a "*" in front of target file name indicates that yesterdays timestamp shold be used when referencing date variables in "strftime" format string. Example: Given the date 30-03-2013 a string "%Y%m%d.csv" will result in filename "20130330", while "*%Y%m%d.csv" will result in filename "20130329".
This seems to be a nice feature.
I have updated to 4.9u and tried this feature but it doesn't work.
In "WSWin data export" I had selected the sensors.
Schedule is "every hour", filenames are "today.csv" and "yesterday.csv".
"Generate WSWIN data ongoing" is on (is this required?)
But both (wswin-today and wswin-yesterday) are not uploaded (other files do).
And they aren't in the folder myweb/uploads.
Are there any other settings required?
Re: Update 4.9u
Posted: Thu Apr 18, 2013 3:24 am
by reicharb
I had a probem with this update on my DC01 and Davis weather station. After I upgraded I could not get any sensor data. I have to install 4.9t and I started recieving data again. Has anyone else seen this problem?
Re: Update 4.9u
Posted: Thu Apr 18, 2013 9:19 am
What kind of Davis station and data logger (serial, usb, tcpip) do you have?
Could you please post "meteohub log" results from "Log Files" page?
Re: Update 4.9u
Posted: Thu Apr 18, 2013 9:20 am
WSWIN daily export feature still has a bug on certain platforms, will be fixed soon.
Re: Update 4.9u
Posted: Thu Apr 18, 2013 4:14 pm
by reicharb
I am setup to use both usb and IP. neither would work.
I emailed the log file to your info@meteohub.de e-mail address. I had trouble attaching.
Re: Update 4.9u
Posted: Sat Apr 20, 2013 10:46 am
I uploaded a hot fix for the bug related to WSWIN daily data upload.
Please install 4.9u again and after that press "save" on "graph upload"
page in order to apply changes to the upload definition in crontab.
Re: Update 4.9u
Posted: Sat Apr 20, 2013 3:00 pm
by cgn
"WSWIN-today" works now, but "WSWIN-yesterday" doesn't. :(
Re: Update 4.9u
Posted: Sat Apr 20, 2013 3:30 pm
sorry, a quote was missing. :roll:
This is fixed now, please "re-update" to 4.9u and press "save" on "graph upload" page.
Re: Update 4.9u
Posted: Sat Apr 20, 2013 4:11 pm
by cgn
Now "WSWIN-yesterday" works too.
Thank you for the quick hotfix. :D
Re: Update 4.9u
Posted: Sat Apr 20, 2013 9:57 pm
by meteo-quimper
Hi Boris
There is another bug with the pressure sensor (Vantage Pro 2) with the update 4.9U (6929,6933):
The data on the graphs are ok for the pressure, but not with the tags...
The bug disapear when i came back to 4.9T
Re: Update 4.9u
Posted: Sun Apr 21, 2013 1:39 am
by awekas
Can someone confirm WSWIN month file creation did not work? if i click on generate wswin month file the message "file creation initiated" was shown but no file in export directory was generated.
On my box no problems with VP2 indoor sensor.
Re: Update 4.9u
Posted: Sun Apr 21, 2013 8:27 am
by wfpost
yes, I can confirm this
wswin creation is dead
seems the tmp file creation starts and creates the file, but it then is not written into the correct monthly file
.wswin-201304.tmp
Re: Update 4.9u
Posted: Sun Apr 21, 2013 1:11 pm
by cgn
I can confirm this, too.
Re: Update 4.9u
Posted: Sun Apr 21, 2013 2:37 pm
by awekas
Boris has now fixed the bug. If you update box once more WSWIN export works well. (no new build number)
currently build 4.9u (Build 6933)
I confirm export works well now.
Othmar
