message FTP upload **solved**
doornenburgweer
Post by doornenburgweer »
sometime I get the next message :
FTP Upload:
2013-04-19 17:22:08 Error: Could not delete old public_html/weather2/uploadMB/, so could not rename public_html/weather2/uploadMB/mb_ to that: remote delete failed
what can I do to this?
Re: message FTP upload
There must be something wrong with delete/write rights on your FTP server.
Meteobridge uploads data first to a temporary filename and (when file is completely uploaded)
renames it to the destination file name. This fails on your FTP server.
Please try renaming/deleting files on your FTP server with a standard FTP client
for your PC and you should be able to further analyze the problem of your FTP account.
doornenburgweer
thanks, this message is sometimes there ( busy server trafic?)
...or may be reached a quota?
aliyahjack
Post by aliyahjack »
If i plug in an ethernet cable i can then access the meteobridge at the same IP as reported for wifi. Is this normal?
________________________
You can easily check out our high quality JN0-643 which prepares you well for 1z0-062 testking. You can also get success in real Pass4-sure exam with the quality hodges and selftestengine.
Yes, it does not have separate MACs for LAN and Wifi. Therefore, it is assigned just one IP for both access methods.
