Mele A2000G
Mele A2000G
Meteohub MiniX image works fine on a mele A2000G. I didn't need to do anything but build the sd card.
Re: Mele A2000G
Several problems I encountered:
- Needed to modify power saving settings in the rtk8192 wifi driver
- Can't connect via wifi until I explicitly add a route to the router
- Meteohub process suddenly terminated this night. I found "expr: division by zero" in /var/log/messages
- Error connecting 127.0.0.1:5555 -> Need to reselect USB-port
Re: Mele A2000G
Weather Data Logging: running (last data: 1 h)
