Davis Pro 2nd soil humidity sensor? **solved**
Medor
Post by Medor »
I have an extra Davis station with 1 soil temp and 2 soil humidity sensors, and the 2nd humidity sensors does not show up on the "live data" page. Anything I can do to see it ?
Re: Davis Pro 2nd soil humidity sensor ?
This is not supported right now, I will have a look at it.
Medor
Post by Medor »
Just to confirm what you probably are already aware of, that just like on the "livedata" page, the 2nd soil sensor is not reported by http://.../livedata.cgi or http://.../livedataxml.cgi.
Medor
Post by Medor »
Up.
I follow from a distance the soil temp and humidity sensors on my Davis station. It has one (1) soil temperature sensor and two (2) soil humidity sensors, respectively at 5cm and 15cm depth. They are all shown on the Davis console.
I can push through HTTP the soil temp with th10temp, the first soil humidity sensor with th10hum. But the second soil humidity sensor th11hum still does not show on the "live" meteobridge page, and more annoyingly is not sent through HTTP.
Would you please look into this ?
Could you please send the MAC of your Meteobridge to "info@meteobridge.com"?
