Solar evo data
doornenburgweer
Solar evo data
Post by doornenburgweer »
The live data page shows me the solar evo, but this data is much too high or wrong.
Is this raw data from the Davis with solar sensor or calculated with teh Pennmann formula?
Re: Solar evo data
It is the daily values as delivered from the Vantage.
doornenburgweer
Re: Solar evo data
But this dat ais not correct, I see too high values, a ET of 52 mm per day is not realistic in this part of the world. and at this moment we can not have an ET of 5.2 already.
Solar evo
5.2mm 0.0mm 52.9mm 0.0mm 52.9mm 0.0mm 52.9mm 0.0mm 71.0mm
maybe it is my Weatherstation? But I see my solar data changing.
regards
gerard
doornenburgweer
Re: Solar evo data
and after resetting all the data I have these readings:
Solar evo 14.2mm
0.56in 0.0mm
0.00in 14.2mm
0.56in 0.0mm
0.00in 0.0mm
0.00in 0.0mm
0.00in 14.2mm
0.56in 0.0mm
0.00in 14.2mm
0.56in
14.2 mm is something for Istanbul in the middle of the summer.
Re: Solar evo data
I would expect the ET value increasing over the day and starting at zero again at midnight.
Having that in mind, I don't understand the series of values you present. Could you please make
your findings a bit more explizit? I don't have a Vantage with solar sensor here, so I cannot
test myself.
Re: Solar evo data
If you send me the MAC of your Meteobridge, I can even login and check myself.
Re: Solar evo data
Thanks for giving me the chance to login. Conversion between mm and inches did go the wrong way.
Will be fixed with next update.
Remark: Values are always sum of the day. No sum up of monthly, yearly values is provided.
doornenburgweer
Re: Solar evo data
okay. thanks
doornenburgweer
Re: Solar evo data
is it possible to use the ET data in a template?
Re: Solar evo data
Yes, should be available as "sol0evo", unit is "mm".
