Weather Data Recomputation
VP2
Post by VP2 »
Hi Guys,
Runing Alix 1D & davis VP2. Since updating to 4.9u (Build 6942) I have had a problem that the Weather Data Recomputation is or seems no longer to be recomputing, all I get on the maintenance page is (in yellow text) is "waiting". So far I have reinstaled 4.9u (Build 6942) - No change, Rebooted - no change and done a full power down for over three hours with no change.
On Power up no Data logging takes place for a number of hours, then all starts to work i.e. outputs data to various weather networks, but still reports that the Weather Data Recomputation status as Waiting this is still the case now some four Days after the last re boot.
Any idea of what is going on and how to get the system back or is it a bug in the lates build ?
Regards Alan
wfpost
Re: Weather Data Recomputation
Post by wfpost »
have you tried to start recomputation manually on the maintenance page?
With my ebox automatic recomp started after updating to 4.9u (Build 6942).
VP2
Post by VP2 »
Hi, Thanks for the reply,
Yes, and after 5 - 10 min no change yellow text "waiting". Prior to the update it would display red boxes/squares whilst recalculating, presumably this was a visual indication of how far along the recalculation was.
Alan
Post by skyewright »
wfpost wrote:With my ebox automatic recomp started after updating to 4.9u (Build 6942).
Same here with ALIX-1D
VP2 wrote: Yes, and after 5 - 10 min no change yellow text "waiting". Prior to the update it would display red boxes/squares whilst recalculating, presumably this was a visual indication of how far along the recalculation was.
Have you looked in any of Meteohub's logs (web interface => Log Files) to see if some sort of problem is being reported there?
VP2
Post by VP2 »
@ Sky
Yes but I cannot see any direct mention for the recomputing, but my knowlage of Linux is next to nothing!!, but here is a bit of the Log :-
logger (24.04.2013 23:21:12): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out.
logger (24.04.2013 23:21:12): station 0 (Vantage), wakeup sent.
logger (24.04.2013 23:21:12): station 0 (Vantage), internal logger activated.
logger (24.04.2013 23:21:12): station 0 (Vantage), syncing.
logger (24.04.2013 23:21:22): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:21:33): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:21:48): station 0 (Vantage), wakeup sent.
logger (24.04.2013 23:21:48): station 0 (Vantage), internal logger activated.
logger (24.04.2013 23:21:48): station 0 (Vantage), syncing.
logger (24.04.2013 23:21:48): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:21:48): station 0 (Vantage), time offset of Vantage: -134 minutes
logger (24.04.2013 23:21:48): station 0 (Vantage), eeprom request sent.
logger (24.04.2013 23:21:48): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (24.04.2013 23:21:48): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (24.04.2013 23:21:48): station 0 (Vantage), transmitter 2 active as station type (#8) "Soil/Leaf".
logger (24.04.2013 23:21:48): station 0 (Vantage), transmitter 3 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (24.04.2013 23:21:48): station 0 (Vantage), version request sent.
logger (24.04.2013 23:21:48): station 0 (Vantage), firmware version 3.12
logger (24.04.2013 23:21:58): station 0 (Vantage), data gap of 4317 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:22:12): station 0 (Vantage), data gap of 4317 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:22:22): station 0 (Vantage), data gap of 4317 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:22:32): station 0 (Vantage), data gap of 4317 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:22:42): station 0 (Vantage), data gap of 4318 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:22:52): station 0 (Vantage), data gap of 4318 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:23:02): station 0 (Vantage), data gap of 4318 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:23:12): station 0 (Vantage), data gap of 4318 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:23:22): station 0 (Vantage), data gap of 4318 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:23:32): station 0 (Vantage), data gap of 4318 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:23:42): station 0 (Vantage), data gap of 4319 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:23:52): station 0 (Vantage), data gap of 4319 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:24:02): station 0 (Vantage), data gap of 4319 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:24:12): station 0 (Vantage), data gap of 4319 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:24:22): station 0 (Vantage), data gap of 4319 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:24:32): station 0 (Vantage), data gap of 4319 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:24:42): station 0 (Vantage), data gap of 4320 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:24:52): station 0 (Vantage), data gap of 4320 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:25:02): station 0 (Vantage), data gap of 4320 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:25:12): station 0 (Vantage), data gap of 4320 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:25:22): station 0 (Vantage), data gap of 4320 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:25:22): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out.
logger (24.04.2013 23:25:22): station 0 (Vantage), wakeup sent.
logger (24.04.2013 23:25:22): station 0 (Vantage), internal logger activated.
logger (24.04.2013 23:25:22): station 0 (Vantage), syncing.
logger (24.04.2013 23:25:32): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:25:42): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:25:57): station 0 (Vantage), wakeup sent.
logger (24.04.2013 23:25:57): station 0 (Vantage), internal logger activated.
logger (24.04.2013 23:25:57): station 0 (Vantage), syncing.
logger (24.04.2013 23:25:57): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:25:57): station 0 (Vantage), time offset of Vantage: -134 minutes
logger (24.04.2013 23:25:57): station 0 (Vantage), eeprom request sent.
logger (24.04.2013 23:25:57): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (24.04.2013 23:25:57): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (24.04.2013 23:25:57): station 0 (Vantage), transmitter 2 active as station type (#8) "Soil/Leaf".
logger (24.04.2013 23:25:57): station 0 (Vantage), transmitter 3 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (24.04.2013 23:25:57): station 0 (Vantage), version request sent.
logger (24.04.2013 23:25:57): station 0 (Vantage), firmware version 3.12
logger (24.04.2013 23:26:07): station 0 (Vantage), data gap of 4321 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:26:17): station 0 (Vantage), data gap of 4321 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:26:27): station 0 (Vantage), data gap of 4321 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:26:37): station 0 (Vantage), data gap of 4321 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:26:47): station 0 (Vantage), data gap of 4322 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:26:57): station 0 (Vantage), data gap of 4322 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:27:11): station 0 (Vantage), data gap of 4322 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:27:21): station 0 (Vantage), data gap of 4322 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:27:31): station 0 (Vantage), data gap of 4322 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:27:41): station 0 (Vantage), data gap of 4323 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:27:51): station 0 (Vantage), data gap of 4323 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:28:01): station 0 (Vantage), data gap of 4323 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:28:11): station 0 (Vantage), data gap of 4323 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:28:21): station 0 (Vantage), data gap of 4323 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:28:31): station 0 (Vantage), data gap of 4323 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:28:41): station 0 (Vantage), data gap of 4324 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:28:51): station 0 (Vantage), data gap of 4324 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:29:01): station 0 (Vantage), data gap of 4324 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:29:11): station 0 (Vantage), data gap of 4324 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:29:21): station 0 (Vantage), data gap of 4324 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:29:31): station 0 (Vantage), data gap of 4324 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:29:41): station 0 (Vantage), data gap of 4325 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:29:51): station 0 (Vantage), data gap of 4325 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:30:01): station 0 (Vantage), data gap of 4325 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:30:11): station 0 (Vantage), data gap of 4325 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:30:21): station 0 (Vantage), data gap of 4325 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:30:31): station 0 (Vantage), data gap of 4325 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:30:41): station 0 (Vantage), data gap of 4326 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:30:51): station 0 (Vantage), data gap of 4326 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:31:01): station 0 (Vantage), data gap of 4326 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:31:11): station 0 (Vantage), data gap of 4326 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:31:21): station 0 (Vantage), data gap of 4326 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:31:31): station 0 (Vantage), data gap of 4326 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:31:41): station 0 (Vantage), data gap of 4327 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:31:52): station 0 (Vantage), data gap of 4327 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:32:06): station 0 (Vantage), data gap of 4327 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:32:16): station 0 (Vantage), data gap of 4327 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:32:26): station 0 (Vantage), data gap of 4327 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:32:36): station 0 (Vantage), data gap of 4327 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:32:46): station 0 (Vantage), data gap of 4328 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:32:56): station 0 (Vantage), data gap of 4328 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:33:06): station 0 (Vantage), data gap of 4328 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:33:16): station 0 (Vantage), data gap of 4328 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:33:26): station 0 (Vantage), data gap of 4328 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:33:36): station 0 (Vantage), data gap of 4328 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:33:46): station 0 (Vantage), data gap of 4329 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:33:56): station 0 (Vantage), data gap of 4329 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:34:06): station 0 (Vantage), data gap of 4329 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:34:16): station 0 (Vantage), data gap of 4329 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:34:26): station 0 (Vantage), data gap of 4329 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:34:36): station 0 (Vantage), data gap of 4329 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:34:46): station 0 (Vantage), data gap of 4330 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:34:56): station 0 (Vantage), data gap of 4330 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:35:06): station 0 (Vantage), data gap of 4330 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:35:17): station 0 (Vantage), data gap of 4330 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:35:27): station 0 (Vantage), data gap of 4330 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:35:37): station 0 (Vantage), data gap of 4330 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:35:47): station 0 (Vantage), data gap of 4331 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:35:57): station 0 (Vantage), data gap of 4331 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:36:07): station 0 (Vantage), data gap of 4331 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:36:17): station 0 (Vantage), data gap of 4331 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:36:27): station 0 (Vantage), data gap of 4331 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:36:37): station 0 (Vantage), data gap of 4331 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:36:47): station 0 (Vantage), data gap of 4332 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:36:57): station 0 (Vantage), data gap of 4332 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:37:11): station 0 (Vantage), data gap of 4332 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:37:21): station 0 (Vantage), data gap of 4332 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:37:32): station 0 (Vantage), data gap of 4332 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:37:42): station 0 (Vantage), data gap of 4333 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:37:52): station 0 (Vantage), data gap of 4333 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:38:02): station 0 (Vantage), data gap of 4333 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:38:12): station 0 (Vantage), data gap of 4333 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:38:22): station 0 (Vantage), data gap of 4333 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:38:32): station 0 (Vantage), data gap of 4333 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:38:42): station 0 (Vantage), data gap of 4334 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:38:52): station 0 (Vantage), data gap of 4334 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:39:02): station 0 (Vantage), data gap of 4334 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:39:12): station 0 (Vantage), data gap of 4334 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:39:22): station 0 (Vantage), data gap of 4334 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:39:32): station 0 (Vantage), data gap of 4334 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:39:42): station 0 (Vantage), data gap of 4335 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:39:52): station 0 (Vantage), data gap of 4335 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:40:02): station 0 (Vantage), data gap of 4335 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:40:12): station 0 (Vantage), data gap of 4335 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:40:22): station 0 (Vantage), data gap of 4335 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:40:22): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out.
logger (24.04.2013 23:40:22): station 0 (Vantage), wakeup sent.
logger (24.04.2013 23:40:22): station 0 (Vantage), internal logger activated.
logger (24.04.2013 23:40:22): station 0 (Vantage), syncing.
logger (24.04.2013 23:40:32): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:40:42): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:40:57): station 0 (Vantage), wakeup sent.
logger (24.04.2013 23:40:57): station 0 (Vantage), internal logger activated.
logger (24.04.2013 23:40:57): station 0 (Vantage), syncing.
logger (24.04.2013 23:40:57): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:40:57): station 0 (Vantage), time offset of Vantage: -134 minutes
logger (24.04.2013 23:40:57): station 0 (Vantage), eeprom request sent.
logger (24.04.2013 23:40:57): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (24.04.2013 23:40:57): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (24.04.2013 23:40:57): station 0 (Vantage), transmitter 2 active as station type (#8) "Soil/Leaf".
logger (24.04.2013 23:40:57): station 0 (Vantage), transmitter 3 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (24.04.2013 23:40:57): station 0 (Vantage), version request sent.
logger (24.04.2013 23:40:57): station 0 (Vantage), firmware version 3.12
logger (24.04.2013 23:41:07): station 0 (Vantage), data gap of 4336 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:41:17): station 0 (Vantage), data gap of 4336 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:41:27): station 0 (Vantage), data gap of 4336 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:41:37): station 0 (Vantage), data gap of 4336 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:41:47): station 0 (Vantage), data gap of 4337 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:41:57): station 0 (Vantage), data gap of 4337 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:42:07): station 0 (Vantage), data gap of 4337 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:42:17): station 0 (Vantage), data gap of 4337 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:42:27): station 0 (Vantage), data gap of 4337 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:42:37): station 0 (Vantage), data gap of 4337 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:42:37): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out.
logger (24.04.2013 23:42:37): station 0 (Vantage), wakeup sent.
logger (24.04.2013 23:42:37): station 0 (Vantage), internal logger activated.
logger (24.04.2013 23:42:37): station 0 (Vantage), syncing.
logger (24.04.2013 23:42:47): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:42:57): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:43:12): station 0 (Vantage), wakeup sent.
logger (24.04.2013 23:43:12): station 0 (Vantage), internal logger activated.
logger (24.04.2013 23:43:12): station 0 (Vantage), syncing.
logger (24.04.2013 23:43:12): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:43:12): station 0 (Vantage), time offset of Vantage: -134 minutes
logger (24.04.2013 23:43:12): station 0 (Vantage), eeprom request sent.
logger (24.04.2013 23:43:12): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (24.04.2013 23:43:12): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (24.04.2013 23:43:12): station 0 (Vantage), transmitter 2 active as station type (#8) "Soil/Leaf".
logger (24.04.2013 23:43:12): station 0 (Vantage), transmitter 3 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (24.04.2013 23:43:12): station 0 (Vantage), version request sent.
logger (24.04.2013 23:43:12): station 0 (Vantage), firmware version 3.12
logger (24.04.2013 23:43:22): station 0 (Vantage), data gap of 4338 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:43:32): station 0 (Vantage), data gap of 4338 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:43:42): station 0 (Vantage), data gap of 4339 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:43:53): station 0 (Vantage), data gap of 4339 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:44:03): station 0 (Vantage), data gap of 4339 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:44:13): station 0 (Vantage), data gap of 4339 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:44:23): station 0 (Vantage), data gap of 4339 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:44:33): station 0 (Vantage), data gap of 4339 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:44:43): station 0 (Vantage), data gap of 4340 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:44:53): station 0 (Vantage), data gap of 4340 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:45:03): station 0 (Vantage), data gap of 4340 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:45:13): station 0 (Vantage), data gap of 4340 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:45:23): station 0 (Vantage), data gap of 4340 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:45:33): station 0 (Vantage), data gap of 4340 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:45:43): station 0 (Vantage), data gap of 4341 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:45:53): station 0 (Vantage), data gap of 4341 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:46:03): station 0 (Vantage), data gap of 4341 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:46:13): station 0 (Vantage), data gap of 4341 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:46:23): station 0 (Vantage), data gap of 4341 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:46:33): station 0 (Vantage), data gap of 4341 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:46:43): station 0 (Vantage), data gap of 4342 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:46:53): station 0 (Vantage), data gap of 4342 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:47:07): station 0 (Vantage), data gap of 4342 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:47:17): station 0 (Vantage), data gap of 4342 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:47:27): station 0 (Vantage), data gap of 4342 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:47:37): station 0 (Vantage), data gap of 4342 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:47:47): station 0 (Vantage), data gap of 4343 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:47:57): station 0 (Vantage), data gap of 4343 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:48:07): station 0 (Vantage), data gap of 4343 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:48:17): station 0 (Vantage), data gap of 4343 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:48:17): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out.
logger (24.04.2013 23:48:17): station 0 (Vantage), wakeup sent.
logger (24.04.2013 23:48:17): station 0 (Vantage), internal logger activated.
logger (24.04.2013 23:48:17): station 0 (Vantage), syncing.
logger (24.04.2013 23:48:27): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:48:37): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:48:52): station 0 (Vantage), wakeup sent.
logger (24.04.2013 23:48:52): station 0 (Vantage), internal logger activated.
logger (24.04.2013 23:48:52): station 0 (Vantage), syncing.
logger (24.04.2013 23:48:52): station 0 (Vantage), gettime request sent.
logger (24.04.2013 23:48:52): station 0 (Vantage), time offset of Vantage: -134 minutes
logger (24.04.2013 23:48:52): station 0 (Vantage), eeprom request sent.
logger (24.04.2013 23:48:52): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (24.04.2013 23:48:52): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (24.04.2013 23:48:52): station 0 (Vantage), transmitter 2 active as station type (#8) "Soil/Leaf".
logger (24.04.2013 23:48:52): station 0 (Vantage), transmitter 3 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (24.04.2013 23:48:52): station 0 (Vantage), version request sent.
logger (24.04.2013 23:48:52): station 0 (Vantage), firmware version 3.12
logger (24.04.2013 23:49:02): station 0 (Vantage), data gap of 4344 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:49:12): station 0 (Vantage), data gap of 4344 minutes, start reading Vantage's internal logger after 2013-04-21 21:10 (Vantage's local time).
logger (24.04.2013 23:49:13): station 0 (Vantage), internal logger provides 0 pages of data.
logger (25.04.2013 01:01:09): error reading from wget process (status): --01:00:54-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
logger (25.04.2013 03:01:25): error reading from wget process (status): --03:01:10-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
loggereval (25.04.2013 04:57:44): illegal data record in line 783572 while reading from file /data/weather/201011/raw: 20101
r�>K@���A�=�?�����}�?���A�=�?loggereval (25.04.2013 04:57:44): illegal data record in line 783619 while reading from file /data/weather/201011/raw: 201LOOloggereval (25.04.2013 04:57:44): illegal data record in line 783620 while reading from file /data/weather/201011/raw:
z
�����snloggereval (25.04.2013 04:57:49): illegal data record in line 56963 while reading from file /data/weather/201012/raw: 20101203041500����Hgm@%d���@MH �Ä׿?����BM@%d���@46 0017 %d���@MH �Ä׿>=ηr׿MH �Ä׿loggereval (25.04.2013 04:57:49): illegal data record in line 57010 while reading from file /data/weather/201012/raw: 2010120304LOO�loggereval (25.04.2013 04:57:49): illegal data record in line 57011 while reading from file /data/weather/201012/raw:
���C�����logger (25.04.2013 05:01:35): error reading from wget process (status): --05:01:35-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Name or service not known.
logger (25.04.2013 15:31:09): data logger (version 4.9u, build 6935) started.
logger (25.04.2013 15:31:09): connect station 0 (Vantage via serial).
logger (25.04.2013 15:31:10): station 0 (Vantage), wakeup sent.
logger (25.04.2013 15:31:10): station 0 (Vantage), internal logger activated.
logger (25.04.2013 15:31:10): station 0 (Vantage), syncing.
logger (25.04.2013 15:31:16): error reading from wget process (status): --15:31:16-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Temporary failure in name resolution.
logger (25.04.2013 15:31:20): station 0 (Vantage), gettime request sent.
logger (25.04.2013 15:31:30): station 0 (Vantage), gettime request sent.
logger (25.04.2013 15:31:40): station 0 (Vantage), gettime request sent.
logger (25.04.2013 15:31:55): station 0 (Vantage), wakeup sent.
logger (25.04.2013 15:31:55): station 0 (Vantage), internal logger activated.
logger (25.04.2013 15:31:55): station 0 (Vantage), syncing.
logger (25.04.2013 15:31:55): station 0 (Vantage), gettime request sent.
logger (25.04.2013 15:31:55): station 0 (Vantage), time offset of Vantage: -134 minutes
logger (25.04.2013 15:31:55): station 0 (Vantage), eeprom request sent.
logger (25.04.2013 15:31:55): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (25.04.2013 15:31:55): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (25.04.2013 15:31:55): station 0 (Vantage), transmitter 2 active as station type (#8) "Soil/Leaf".
logger (25.04.2013 15:31:55): station 0 (Vantage), transmitter 3 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (25.04.2013 15:31:55): station 0 (Vantage), version request sent.
logger (25.04.2013 15:31:55): station 0 (Vantage), firmware version 3.12
logger (25.04.2013 15:31:55): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 364 secs
logger (25.04.2013 15:41:21): error reading from wget process (status): --15:41:21-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Temporary failure in name resolution.
logger (25.04.2013 21:30:11): data logger (version 4.9u, build 6935) started.
logger (25.04.2013 21:30:11): connect station 0 (Vantage via serial).
logger (25.04.2013 21:30:12): station 0 (Vantage), wakeup sent.
logger (25.04.2013 21:30:12): station 0 (Vantage), internal logger activated.
logger (25.04.2013 21:30:12): station 0 (Vantage), syncing.
logger (25.04.2013 21:30:22): station 0 (Vantage), gettime request sent.
logger (25.04.2013 21:30:32): station 0 (Vantage), gettime request sent.
logger (25.04.2013 21:30:42): station 0 (Vantage), gettime request sent.
logger (25.04.2013 21:30:57): station 0 (Vantage), wakeup sent.
logger (25.04.2013 21:30:57): station 0 (Vantage), internal logger activated.
logger (25.04.2013 21:30:57): station 0 (Vantage), syncing.
logger (25.04.2013 21:30:57): station 0 (Vantage), gettime request sent.
logger (25.04.2013 21:30:57): station 0 (Vantage), time offset of Vantage: -134 minutes
logger (25.04.2013 21:30:57): station 0 (Vantage), eeprom request sent.
logger (25.04.2013 21:30:57): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (25.04.2013 21:30:57): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (25.04.2013 21:30:57): station 0 (Vantage), transmitter 2 active as station type (#8) "Soil/Leaf".
logger (25.04.2013 21:30:57): station 0 (Vantage), transmitter 3 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (25.04.2013 21:30:57): station 0 (Vantage), version request sent.
logger (25.04.2013 21:30:57): station 0 (Vantage), firmware version 3.12
logger (25.04.2013 21:30:57): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 484 secs
logger (25.04.2013 23:00:50): error reading from wget process (status): --23:00:35-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
logger (26.04.2013 01:01:14): error reading from wget process (status): --01:00:59-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
logger (26.04.2013 03:01:25): error reading from wget process (status): --03:01:20-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Name or service not known.
loggereval (26.04.2013 04:57:54): illegal data record in line 783572 while reading from file /data/weather/201011/raw: 20101
r�>K@���A�=�?�����}�?���A�=�?loggereval (26.04.2013 04:57:54): illegal data record in line 783619 while reading from file /data/weather/201011/raw: 201LOOloggereval (26.04.2013 04:57:54): illegal data record in line 783620 while reading from file /data/weather/201011/raw:
z
�����snloggereval (26.04.2013 04:57:59): illegal data record in line 56963 while reading from file /data/weather/201012/raw: 20101203041500����Hgm@%d���@MH �Ä׿?����BM@%d���@46 0017 %d���@MH �Ä׿>=ηr׿MH �Ä׿loggereval (26.04.2013 04:57:59): illegal data record in line 57010 while reading from file /data/weather/201012/raw: 2010120304LOO�loggereval (26.04.2013 04:57:59): illegal data record in line 57011 while reading from file /data/weather/201012/raw:
���C�����loggereval (27.04.2013 04:58:07): illegal data record in line 783572 while reading from file /data/weather/201011/raw: 20101
r�>K@���A�=�?�����}�?���A�=�?loggereval (27.04.2013 04:58:07): illegal data record in line 783619 while reading from file /data/weather/201011/raw: 201LOOloggereval (27.04.2013 04:58:07): illegal data record in line 783620 while reading from file /data/weather/201011/raw:
z
�����snloggereval (27.04.2013 04:58:15): illegal data record in line 56963 while reading from file /data/weather/201012/raw: 20101203041500����Hgm@%d���@MH �Ä׿?����BM@%d���@46 0017 %d���@MH �Ä׿>=ηr׿MH �Ä׿loggereval (27.04.2013 04:58:15): illegal data record in line 57010 while reading from file /data/weather/201012/raw: 2010120304LOO�loggereval (27.04.2013 04:58:15): illegal data record in line 57011 while reading from file /data/weather/201012/raw:
���C�����logger (27.04.2013 16:59:35): error reading from wget process (status): --16:59:20-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
logger (27.04.2013 19:00:00): error reading from wget process (status): --18:59:45-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
logger (27.04.2013 19:46:58): parent process received termination signal (15).
logger (27.04.2013 19:46:58): child process received termination signal (15).
logger (27.04.2013 19:47:01): disconnect station 0 (Vantage).
logger (27.04.2013 19:47:02): data logger stopped.
logger (27.04.2013 19:47:13): data logger (version 4.9u, build 6935) started.
logger (27.04.2013 19:47:14): connect station 0 (Vantage via serial).
logger (27.04.2013 19:47:15): station 0 (Vantage), wakeup sent.
logger (27.04.2013 19:47:15): station 0 (Vantage), internal logger activated.
logger (27.04.2013 19:47:15): station 0 (Vantage), syncing.
logger (27.04.2013 19:47:27): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:47:38): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:47:49): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:48:00): station 0 (Vantage), wakeup sent.
logger (27.04.2013 19:48:00): station 0 (Vantage), internal logger activated.
logger (27.04.2013 19:48:00): station 0 (Vantage), syncing.
logger (27.04.2013 19:48:00): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:48:00): station 0 (Vantage), time offset of Vantage: -134 minutes
logger (27.04.2013 19:48:00): station 0 (Vantage), eeprom request sent.
logger (27.04.2013 19:48:00): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (27.04.2013 19:48:00): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (27.04.2013 19:48:00): station 0 (Vantage), transmitter 2 active as station type (#8) "Soil/Leaf".
logger (27.04.2013 19:48:00): station 0 (Vantage), transmitter 3 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (27.04.2013 19:48:00): station 0 (Vantage), version request sent.
logger (27.04.2013 19:48:00): station 0 (Vantage), firmware version 3.12
logger (27.04.2013 19:48:00): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 82 secs
logger (27.04.2013 19:48:17): parent process received termination signal (15).
logger (27.04.2013 19:48:17): child process received termination signal (15).
logger (27.04.2013 19:48:21): disconnect station 0 (Vantage).
logger (27.04.2013 19:48:22): data logger stopped.
logger (27.04.2013 19:48:34): data logger (version 4.9u, build 6935) started.
logger (27.04.2013 19:48:34): connect station 0 (Vantage via serial).
logger (27.04.2013 19:48:35): station 0 (Vantage), wakeup sent.
logger (27.04.2013 19:48:35): station 0 (Vantage), internal logger activated.
logger (27.04.2013 19:48:35): station 0 (Vantage), syncing.
logger (27.04.2013 19:48:48): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:48:59): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:49:10): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:49:21): station 0 (Vantage), wakeup sent.
logger (27.04.2013 19:49:21): station 0 (Vantage), internal logger activated.
logger (27.04.2013 19:49:21): station 0 (Vantage), syncing.
logger (27.04.2013 19:49:21): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:49:21): station 0 (Vantage), time offset of Vantage: -134 minutes
logger (27.04.2013 19:49:21): station 0 (Vantage), eeprom request sent.
logger (27.04.2013 19:49:21): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (27.04.2013 19:49:21): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (27.04.2013 19:49:21): station 0 (Vantage), transmitter 2 active as station type (#8) "Soil/Leaf".
logger (27.04.2013 19:49:21): station 0 (Vantage), transmitter 3 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (27.04.2013 19:49:21): station 0 (Vantage), version request sent.
logger (27.04.2013 19:49:22): station 0 (Vantage), firmware version 3.12
logger (27.04.2013 19:49:22): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 72 secs
logger (27.04.2013 19:49:51): parent process received termination signal (15).
logger (27.04.2013 19:49:51): child process received termination signal (15).
logger (27.04.2013 19:49:54): disconnect station 0 (Vantage).
logger (27.04.2013 19:49:54): data logger stopped.
logger (27.04.2013 19:51:11): data logger (version 4.9u, build 6956) started.
logger (27.04.2013 19:51:13): connect station 0 (Vantage via serial).
logger (27.04.2013 19:51:13): station 0 (Vantage), wakeup sent.
logger (27.04.2013 19:51:13): station 0 (Vantage), internal logger activated.
logger (27.04.2013 19:51:13): station 0 (Vantage), syncing.
logger (27.04.2013 19:51:24): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:51:35): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:51:45): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:51:57): station 0 (Vantage), wakeup sent.
logger (27.04.2013 19:51:57): station 0 (Vantage), internal logger activated.
logger (27.04.2013 19:51:57): station 0 (Vantage), syncing.
logger (27.04.2013 19:51:57): station 0 (Vantage), gettime request sent.
logger (27.04.2013 19:51:57): station 0 (Vantage), time offset of Vantage: -134 minutes
logger (27.04.2013 19:51:57): station 0 (Vantage), eeprom request sent.
logger (27.04.2013 19:51:57): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (27.04.2013 19:51:57): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (27.04.2013 19:51:57): station 0 (Vantage), transmitter 2 active as station type (#8) "Soil/Leaf".
logger (27.04.2013 19:51:57): station 0 (Vantage), transmitter 3 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (27.04.2013 19:51:57): station 0 (Vantage), firmware version request sent.
logger (27.04.2013 19:51:57): station 0 (Vantage), no firmware version returned.
logger (27.04.2013 19:51:57): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 145 secs
loggereval (28.04.2013 04:58:55): illegal data record in line 783572 while reading from file /data/weather/201011/raw: 20101
r�>K@���A�=�?�����}�?���A�=�?loggereval (28.04.2013 04:58:55): illegal data record in line 783619 while reading from file /data/weather/201011/raw: 201LOOloggereval (28.04.2013 04:58:55): illegal data record in line 783620 while reading from file /data/weather/201011/raw:
z
�����snloggereval (28.04.2013 04:59:00): illegal data record in line 56963 while reading from file /data/weather/201012/raw: 20101203041500����Hgm@%d���@MH �Ä׿?����BM@%d���@46 0017 %d���@MH �Ä׿>=ηr׿MH �Ä׿loggereval (28.04.2013 04:59:00): illegal data record in line 57010 while reading from file /data/weather/201012/raw: 2010120304LOO�loggereval (28.04.2013 04:59:00): illegal data record in line 57011 while reading from file /data/weather/201012/raw:
���C�����logger (29.04.2013 02:59:11): error reading from wget process (status): --02:58:56-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
loggereval (29.04.2013 04:59:14): illegal data record in line 783572 while reading from file /data/weather/201011/raw: 20101
r�>K@���A�=�?�����}�?���A�=�?loggereval (29.04.2013 04:59:14): illegal data record in line 783619 while reading from file /data/weather/201011/raw: 201LOOloggereval (29.04.2013 04:59:14): illegal data record in line 783620 while reading from file /data/weather/201011/raw:
z
�����snloggereval (29.04.2013 04:59:21): illegal data record in line 56963 while reading from file /data/weather/201012/raw: 20101203041500����Hgm@%d���@MH �Ä׿?����BM@%d���@46 0017 %d���@MH �Ä׿>=ηr׿MH �Ä׿loggereval (29.04.2013 04:59:21): illegal data record in line 57010 while reading from file /data/weather/201012/raw: 2010120304LOO�loggereval (29.04.2013 04:59:21): illegal data record in line 57011 while reading from file /data/weather/201012/raw:
���C�����logger (29.04.2013 04:59:33): error reading from wget process (status): --04:59:18-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
logger (29.04.2013 07:00:13): error reading from wget process (status): --06:59:58-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
logger (29.04.2013 09:00:41): error reading from wget process (status): --09:00:26-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
logger (29.04.2013 11:01:02): error reading from wget process (status): --11:00:47-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Connection timed out.
logger (29.04.2013 13:01:15): error reading from wget process (status): --13:01:15-- http://logger.meteoplug.com/cgi-bin/lograw.pl# =# `-'#Resolving logger.meteoplug.com... failed: Name or service not known.
loggereval (30.04.2013 04:59:28): illegal data record in line 783572 while reading from file /data/weather/201011/raw: 20101
r�>K@���A�=�?�����}�?���A�=�?loggereval (30.04.2013 04:59:28): illegal data record in line 783619 while reading from file /data/weather/201011/raw: 201LOOloggereval (30.04.2013 04:59:28): illegal data record in line 783620 while reading from file /data/weather/201011/raw:
z
�����snloggereval (30.04.2013 04:59:33): illegal data record in line 56963 while reading from file /data/weather/201012/raw: 20101203041500����Hgm@%d���@MH �Ä׿?����BM@%d���@46 0017 %d���@MH �Ä׿>=ηr׿MH �Ä׿loggereval (30.04.2013 04:59:33): illegal data record in line 57010 while reading from file /data/weather/201012/raw: 2010120304LOO�loggereval (30.04.2013 04:59:33): illegal data record in line 57011 while reading from file /data/weather/201012/raw:
���C�����loggereval (01.05.2013 04:55:25): illegal data record in line 783572 while reading from file /data/weather/201011/raw: 20101
r�>K@���A�=�?�����}�?���A�=�?loggereval (01.05.2013 04:55:25): illegal data record in line 783619 while reading from file /data/weather/201011/raw: 201LOOloggereval (01.05.2013 04:55:25): illegal data record in line 783620 while reading from file /data/weather/201011/raw:
z
�����snloggereval (01.05.2013 04:55:33): illegal data record in line 56963 while reading from file /data/weather/201012/raw: 20101203041500����Hgm@%d���@MH �Ä׿?����BM@%d���@46 0017 %d���@MH �Ä׿>=ηr׿MH �Ä׿loggereval (01.05.2013 04:55:33): illegal data record in line 57010 while reading from file /data/weather/201012/raw: 2010120304LOO�loggereval (01.05.2013 04:55:33): illegal data record in line 57011 while reading from file /data/weather/201012/raw:
���C�����
somewhat beyond my ken, but hopfully a help to some one in unraveling this issue, Thanks to all out there in advance.
Cheers Alan
Your file system on flash storage (SD card or USB stick) is damaged.
Please setup a new flash media.
dadi
Post by dadi »
I have Alix 3D2 with meteohub 4.9w
It bothers me that the weather data recomputation occurs only sometimes - for example, monthly or yearly rainfall is displayed correctly in the course of a few hours. Can I set meteohub so that recomputation Weather data was continually?
Thank you.
Daniel Neumann
Plzen, CZ
no, as it goes through all the raw data this cannot be done every few minutes.
dadi
Post by dadi »
admin wrote:no, as it goes through all the raw data this cannot be done every few minutes.
OK, thank you.
