HELP, I misconfigured network settings and can't reach it!
General information and solutions to the most prominent issues
Wait until unit drops into fast blink mode about one minute after reboot.
Then press button on top, led will go off, keep button pressed until led goes on again, release button.
Unit wiil restart in default network configuration, which means it will receive its IP via a DHCP server in your LAN.
When unit reaches steady led on mode, you can reach it via IP given by DHCP server (mostly your router) or by browsing to "http://magicip.meteobridge.com".
You might also consult the wiki to learn about how to find out IP and how to set the unitback to defaults:
http://meteobridge.com/wiki/index.php/G ... findout_ip
