No network trafic with release 1.5 (1927)
After reboot the Meteobridge stopped uploading.
Button Test Upload on tab Push Services works OK. The file is uploaded to the webserver.
But Individual FTP and HTTP upload do not work.
Relead templates works (I think as a correct message is shown).
Live data tab shows No weather network traffic for HTTP and No upload for FTP.
To test if there was a problem with network settings I switched from Set manually to DHCP, system reboots, no upload.
System tab show correct internal and external IP address and gateway.
DNS IP is 127.0.0.1 ? Is this the reason for the error? But DNS works for the test upload.
The problem was solved by restarting the Davis Weatherstation which is connected via IP.
The meteobridge restarted and everything works again.
