I wanted to advise that I am still experiencing an outstanding issue with rainfall. on Weather Underground, when I pull up the station information specific to my station, I do see my rainfall amount for today (0.91"), but when I go to their map and show all the stations precip, it is showing zero... now also in Weatherbug I am showing zero, and my monthly is zero as well it never changes, so I believe the problem is deeper in the firmware and once that is corrected, things may start working. I also noted I do report to Mesowest through the APRSWxNet and they cannot show the 1 hr, 3 hr, 6 hr,ONLY 24 hour rainfall shows and none of the precipitation graphs seem to show a rain chart , the 24 hour amount was accurate.
also on a side note, I sometimes go out and check a manually read gauge with my davis, and will update the daily rainfall on the console, maybe changing it from 0.33 back to 0.29" if its over reading, I notice meteohub doesnt note this change and just keeps adding on to the higher value. Is there something I can do with in meteohub to reflect the change...
Meteohub Rainfall issues exist
