Cannot logon to WL-330N3G
pvelzen
Post by pvelzen »
I Bought a WL-330N3G (Awekas, complete with installed meteobridge) and connected it to my router bij LAN. At first I succeeded in connecting to the WL by using my laptop. Then I shutted the power of the WL and started it again. From that moment I couldn't connect to my WL using my laptop. I've logged in to my modem/router and I could see that an IP-adress was assigned to my WL. But when I use this adress to login it doesn't work. The power button on my WL is blinking rapidly. I've tried to push the WPS button several times, but each time it's resulting in rapid blinking of the led and no connection. What can I do?
Regards, Paul
Re: Cannot logon to WL-330N3G
please try again, should work now.
There was a server fault that prevented from downloading the application stack. Looks like all in all 10 stations were demanding a download caused by a restart/reboot that could not be served during that time frame. As said, things are back to normal operation right now.
pvelzen
Post by pvelzen »
Thank you. It works now! Post can be closed!
