I am currently working on coding a php script to collect the data to the recorded.
My concern is that I'm looking in the files clientraw.txt
clientrawdaily.txt
clientrawextra.txt
clientrawhour.txt
impossible to find the speed of the wind.
Can you confirm the presence of give?
thank you
impossible to find the speed of the wind in clientraw.txt
Re: impossible to find the speed of the wind in clientraw.tx
At http://www.weerstation-leuven.be/weathe ... MH&lang=enmanu13 wrote:Hello,
clientrawdaily.txt
clientrawextra.txt
clientrawhour.txt
thank you
you can ceck your own clientraw files. Also a description of every field in the clientraw is given.
The windspeed is the second field. The speed is in knots
At http://www.weerstation-leuven.be/weathe ... wp=MH#wind
you find a table with all field from the 4 clientraw files sorted by fieldname.
There you find all wind fields and there location in the clientraw files.
I hope this will help with your development.
