Meteohub error when try to read Envoy internal logger
el-rain
Post by el-rain »
to clean up some old data of my old external sensor th0 which transmit wrong temp value I see a problem when reenable logging again.
- the "sensor data, "humidity" (110) out of range [0:100]" error comes back while it was no shown for some days, at least not since I cleared the meteohub log last time on 13th. June
- Getting an error to read data out of the Envoy logger. See logs below.
Equipment ISS sending data to an Envoy (FW1.90) connected with original USB Logger to Meteohub 4.9u (Build 1375) on a iConnect.
Any clue what causes this issue !?
2013.06.13 15:05:51 log file cleared by user
logger (19.06.2013 08:17:33): parent process received termination signal (15).
logger (19.06.2013 08:17:33): child process received termination signal (15).
logger (19.06.2013 08:36:50): data logger (version 4.9u, build 1376) started.
logger (19.06.2013 08:36:51): connect station 0 (Vantage via USB serial).
logger (19.06.2013 08:36:51): connect station 1 (WS2300 via USB serial).
logger (19.06.2013 08:36:52): station 0 (Vantage), wakeup sent.
logger (19.06.2013 08:36:52): station 0 (Vantage), internal logger activated.
logger (19.06.2013 08:36:52): station 0 (Vantage), syncing.
logger (19.06.2013 08:36:55): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:37:02): station 0 (Vantage), gettime request sent.
logger (19.06.2013 08:37:02): station 0 (Vantage), time offset of Vantage: -62 minutes
logger (19.06.2013 08:37:02): station 0 (Vantage), eeprom request sent.
logger (19.06.2013 08:37:02): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (19.06.2013 08:37:02): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (19.06.2013 08:37:02): station 0 (Vantage), firmware version request sent.
logger (19.06.2013 08:37:02): station 0 (Vantage), firmware version 2.00
logger (19.06.2013 08:37:12): station 0 (Vantage), data gap of 20 minutes, start reading Vantage's internal logger after 2013-06-19 07:10 (Vantage's local time).
logger (19.06.2013 08:37:13): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:37:23): station 0 (Vantage), data gap of 20 minutes, start reading Vantage's internal logger after 2013-06-19 07:10 (Vantage's local time).
logger (19.06.2013 08:37:23): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out (try #1).
logger (19.06.2013 08:37:23): station 0 (Vantage), wakeup sent.
logger (19.06.2013 08:37:23): station 0 (Vantage), internal logger activated.
logger (19.06.2013 08:37:23): station 0 (Vantage), syncing.
logger (19.06.2013 08:37:33): station 0 (Vantage), gettime request sent.
logger (19.06.2013 08:37:33): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:37:33): station 0 (Vantage), time offset of Vantage: -62 minutes
logger (19.06.2013 08:37:33): station 0 (Vantage), eeprom request sent.
logger (19.06.2013 08:37:33): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (19.06.2013 08:37:33): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (19.06.2013 08:37:33): station 0 (Vantage), firmware version request sent.
logger (19.06.2013 08:37:33): station 0 (Vantage), firmware version 2.00
logger (19.06.2013 08:37:43): station 0 (Vantage), data gap of 20 minutes, start reading Vantage's internal logger after 2013-06-19 07:10 (Vantage's local time).
logger (19.06.2013 08:37:52): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:37:57): station 0 (Vantage), data gap of 21 minutes, start reading Vantage's internal logger after 2013-06-19 07:10 (Vantage's local time).
logger (19.06.2013 08:37:57): station 0 (Vantage), wrong checksum of DMPAFT response, restarting logger read out (try #2).
logger (19.06.2013 08:37:57): station 0 (Vantage), wakeup sent.
logger (19.06.2013 08:37:58): station 0 (Vantage), internal logger activated.
logger (19.06.2013 08:37:58): station 0 (Vantage), syncing.
logger (19.06.2013 08:38:12): station 0 (Vantage), gettime request sent.
logger (19.06.2013 08:38:13): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:38:23): disconnect station 0 (Vantage).
logger (19.06.2013 08:38:33): station 0 (Vantage), kernel module "cp2101 cp210x" reloaded, module messages: ERROR: Module cp210x is in use FATAL: Module cp2101 not found.
logger (19.06.2013 08:38:33): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:38:52): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:38:54): connect station 0 (Vantage via USB serial).
logger (19.06.2013 08:38:59): station 0 (Vantage), wakeup sent.
logger (19.06.2013 08:38:59): station 0 (Vantage), internal logger activated.
logger (19.06.2013 08:38:59): station 0 (Vantage), syncing.
logger (19.06.2013 08:39:10): station 0 (Vantage), gettime request sent.
logger (19.06.2013 08:39:10): station 0 (Vantage), time offset of Vantage: -62 minutes
logger (19.06.2013 08:39:10): station 0 (Vantage), eeprom request sent.
logger (19.06.2013 08:39:10): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (19.06.2013 08:39:10): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (19.06.2013 08:39:10): station 0 (Vantage), firmware version request sent.
logger (19.06.2013 08:39:11): station 0 (Vantage), firmware version 2.00
logger (19.06.2013 08:39:12): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:39:22): station 0 (Vantage), data gap of 22 minutes, start reading Vantage's internal logger after 2013-06-19 07:10 (Vantage's local time).
logger (19.06.2013 08:39:33): station 0 (Vantage), data gap of 22 minutes, start reading Vantage's internal logger after 2013-06-19 07:10 (Vantage's local time).
logger (19.06.2013 08:39:33): station 0 (Vantage), wrong checksum of DMPAFT response, skipping logger read out.
logger (19.06.2013 08:39:33): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:39:51): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:40:12): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:40:34): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
logger (19.06.2013 08:40:53): Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
20130619061712 thb0 287 48 0166 10047 2 10123
20130619061712 wind0 57 4 0 0211
20130619061712 thb1 284 37 0123 10042 1 10130
20130619061719 wind0 68 4 0 0211
20130619061723 rain0 0 0 221
20130619061732 thb1 284 37 0123 10042 1 10130
20130619063713 thb1 283 37 0122 10040 1 10128
20130619063733 thb1 283 37 0122 10040 1 10128
20130619063752 thb1 283 37 0122 10038 0 10126
20130619063813 thb1 283 37 0122 10038 0 10126
20130619063833 thb1 283 37 0122 10038 0 10126
20130619063852 thb1 283 37 0122 10039 0 10127
20130619063912 thb1 283 37 0122 10039 0 10127
20130619063933 thb1 283 37 0122 10039 0 10127
20130619063938 th0 218 80 0182
20130619063938 wind0 100 9 9 0218
20130619063938 rain0 0 0 221
20130619063939 thb0 286 48 0165 10044 2 10120
20130619063939 wind0 100 4 9 0218
Bye
El
Re: Meteohub error when try to read Envoy internal logger
please update to newest 4.9u.
