Mini Xplus doesn't boot Micro SD
Allwinner A10 systems
DaveBonn
Post by DaveBonn »
I've a Mini Xplus (H24) and today I tried to boot Meteohub (Mini Xplus image) on a micro sd-card. But only the red led turns on and nothing happens.
Is there a solution to this problem?
Dave
DaveBonn
Re: Mini Xplus doesn't boot Micro SD
Post by DaveBonn »
I've solved the Problem, I've bought a Iconnect ;)
Thank you for the support.
Dave
Nelson143
Post by Nelson143 »
With the SD card removed, the Mini X Plus 1GB boots into Android and when I insert the SD card I can see all the files on it. However when I power up the Mini X with the SD inserted the LED turns red but the screen stays blank even if left for several hours.
I have tried two 8GB SD cards one is a class 10 ultra and the other is a class 4 and I have tried copying the image onto the cards using both dd on OSX and Image Writer on Windows - both completed copying without errors.
Cut down your exam HP2-B109 exam by using our latest cert killer Braindumps.com high quality coloradomesa.edu gmat and artinstitutesmiami gre.
