Meteoplug graphs in Meteobridge/Meteohub template
Just two links to see the possibilities of Meteoplugs graphs in my Leuven-template
First the "old" startpage: http://www.wiri.be/weather2/index.php?p=10
and then the new one: http://www.wiri.be/weather2/index.php?p=10-1
As this is a demonstration site the upload times are longer than you would use on your own site, so the windrose will not move quickly as it could.
But I tested it with a "10 seconds" upload and it really looks great.
As the GooglePlaystore is not supporting Flash anymore for new bought devices (mine old one broke, bought a new Android tablet, no Flash anymore), it is also very helpfull that graphs with Meteoplug can be rendered with javascript also. Most of the template is already HTML5, so I still have to do some learning of the graphing language on Meteoplug to get all needed graphs in javascript. One script I will put in the Meteobridge template shortly: http://www.wiri.be/weather2/index.php?p=65&lang=en.
Another Meteoplug "advantage" is that WD-live die-hards can use the Meteoplug server to display a basic WD-live screen (although using Flash) without buying a WD-live key. Indeed a basic screen, not adaptable but in some cases it is all that is needed. Example: http://www.weerstation-herent.be/weathe ... x.php?p=23
Wim van der Kuil
