Tags with UTC date/time not working
saratogaWX
Post by saratogaWX »
Boris,
The docs at http://www.meteobridge.com/wiki/index.php/Templates show
When a capital "U" preceeds a date/time variable name, UTC is used instead of local time ("[Uhh]:[Umm]:[Uss] UTC" is evaluated to a string like "16:03:33 UTC")
and when code like this is used as a template
date|[YYYY]-[MM]-[DD]|// local date:|:
time|[hh]:[mm]:[ss]|// local time:|:
dateUTC|[UYYYY]-[UMM]-[UDD]|// UTC date:|:
timeUTC|[Uhh]:[Umm]:[Uss]|// UTCtime:|:
the values for time and timeUTC are identical (and are local timezone time). I suspect that the dateUTC would also be the local time's date also.
So, it appear that the 'U' modifier is not being honored in the template processing. I'm running Meteobridge 1.8 (2198) on a TL-MR3020
Best regards,
Ken
Free Weather website PHP templates and scripts at Saratoga-Weather.org
Re: Tags with UTC date/time not working
You are right, I can confirm the bug. Will be solved this evening.
villiewe
Post by villiewe »
Display of UTC versus CDT:
I have system set to display CDT but when I click on wunderground map for my station, the daily plot displays UTC.
Meteobridge does always send UTC timestamped data to WU.
When data WU presents to you is not in you local timezone,
then your profile setings in WU is wrong, or WU does have a problem.
villiewe
Post by villiewe »
I checked meteobridge settings and it is definitely time zone "America Chicago"
Where should I email a screen shot that shows CDT settings but plots as UTC ( five hours later)
harvestcoyote
Post by harvestcoyote »
It is actually a confirmed issue with WU; they are switching over databases and the Timezone and Station Altitude values are not working at the moment.
