a few weeks ago I have, in the course of home-automatisation, bought an ELV Homematic WDC-7000 weather station.
Now, a few days ago, I stumbled over your program "Meteohub ".
Unfortunately, the hardware components listed on the Meteohub homepage are no longer available (my favorite was the "Mini X"), too slow or too expensive.
In the forum I found a post (viewtopic.php?f=53&t=9419), which confirms the functionality using a "PCDuino board" (with 1GB RAM).
Since I have a PCDunino-Lite Board (512MB RAM) (http://www.pcduino.com/?page_id=1707) around, I directly tried this with the Mini X -ISO (for the 512 MB version).
The system boots without problems, the update was found, and also installed easily (it is now running version 4.9 V).
Unfortunately, the USB port doesn't recognize the weather station (direct connection and plugging multiple USB hubs (1.x and 2.0) in between were tried).
Therefore I would be very glad if you or anybody else can help me?
The pcDunio-Lite board might also functioning in your hardware list for Meteohub as a good "top-seller" with only 39,- EUROs.
I would like to lend you the board for development purposes if needed.
I would like to have not just Meteoplug used ( which I would then probably use due to the cheap and available hw when pcDuino is not working) but in addition also the local storage by Meteohub would be appreciated.
Thanks and best regards
Boris
