AGAIN, RED Xed AIR CAM DESPITE INITI'Z SUCCESS **solved**
villiewe
Post by villiewe »
A firmware upgrade was required to solve red x next to air cam despite successful initialization for my first meteobridge:
I have installed a second meteo bridge at a remote location today and it has the same issue with initialization being successful but AIRCAM (same model as first MB) has REd x next to it.
I will forward screen shots of error message and meteobridge MAC number.
Re: AGAIN, RED Xed AIR CAM DESPITE INITI'Z SUCCESS ON 2ND MB
should be solved with latest update (November, 20)
viennaxmas
Re: AGAIN, RED Xed AIR CAM DESPITE INITI'Z SUCCESS **solved*
Post by viennaxmas »
which firmware version would this be? I am on Linux 3.3.8 mips (BE), FW 1.4, MeteoBridge 2.3 (4298) and have the same issue.
It does work fine when I use the cam with "External Picture" by entering http://192.168.Ix.x/snapshot.cgi?chan=1
Aircam is Version 1.2, HTTP is set and "allow Screenshot without user authentication is also checked".
Your description does not allow me to drill down on the issue.
When you send your MAC to "info(at)meteobridge.com" I might be able to login and check myself.
