Problems with LuCI and firewall
ctann
Post by ctann »
I am using the MeteoBridge "Advanced mode", and ran into a problem.
MeteoBridge on top of Open Wrt Barrier Breaker r34065
When I go to the interfaces tab and click on "firewall", I get:
/usr/lib/lua/luci/dispatcher.lua:448: Failed to execute function dispatcher target for entry '/admin/network/firewall'.
The called action terminated with an exception:
/usr/lib/lua/luci/dispatcher.lua:448: Failed to execute arcombine dispatcher target for entry '/admin/network/firewall/zones'.
/usr/lib/lua/luci/cbi.lua:336: Unable to read UCI data: firewall
stack traceback:
[C]: in function 'assert'
/usr/lib/lua/luci/dispatcher.lua:448: in function 'dispatch'
/usr/lib/lua/luci/dispatcher.lua:195: in function </usr/lib/lua/luci/dispatcher.lua:194>
Any clues? I would rather use the LuCI interface than hack the config files directly...
Chris.
Re: Problems with LuCI and firewall
I had to keep the install as minimal as possible because we just have 4 MB of flash, which is close to nothing.
When you go patching files, please be aware that I will not support on any problems. Every man for himself ;-)
