meteobridge reset from remote location
Richard Whitmarsh
Post by Richard Whitmarsh »
I use the meteobridge with Davis Vantage Vue at my school/work site and the internet went down today after I left work. However, when the internet came back up, the connection and updating to my weather network was lost. I suspect that a reset is necessary, and I will check upon returning to the school site. In the event that this occurs again, is there any way for an end-user/owner to perform a reset from a remote location? I understand that meteobridge supports remote login... So, it must be possible. Please advise, as I would like to avoid any future interruption in data flow. Thanks.
Richard Whitmarsh
Re: meteobridge reset from remote location
Again...is there any way for an end-user/owner to perform a reset from a remote location? I understand that meteobridge supports remote login... So, it must be possible. Please advise, as I would like to avoid any future interruption in data flow. Thanks.
there is no way.
wfpost
Post by wfpost »
maybe such a gadget, if meteobridge comes and boots up after a power cycle
Good point! Yes, this will work ;-)
villiewe
Post by villiewe »
By remote reset, do you mean a remote reboot?
In remote router, I have set port forwarding of meteobridge LAN IP address to port 80. Then in browser at home, I enter WAN address of meteobridge router, followed by :80
The control panel of meteobridge is then displayed and can be rebooted.
tomschultz
Post by tomschultz »
Villiewe,
Would this allow me to make changes to the "Push Services" tab from home and not at the location of the weather station?
Tom
villiewe
Post by villiewe »
I have found that all meteobridge tabs are accessible from home if router " port forwarding" is set so that port 80 goes to the LAN of the meteobridge.
Also set port forwarding for port 22 to the LAN IP of the meteo bridge. ( I don't know why port 22 is done or if it is even necessary but setting 22 & 80m this way works getting to meteobridge tabs)
For the URL window at home, type in router WAN followed by :80 no spaces
