deleting meteobridge connection to air cam?
villiewe
Post by villiewe »
I have successfully set ubiquiti camera to upload to meteobridge servers. How do I delete that weather network to camera connection?
I want to connect the camera to other software, but cannot access the camera by the other software and I am hoping, if the meteobridge-camera connect is removed, I will be able to access the camera with other software
Re: deleting meteobridge connection to air cam?
Meteobridge does not hold a lock on the AirCam, so other software will be able to connect to it als well.
villiewe
Post by villiewe »
OK, but I still want to delete the meteobridge connection to the ubiquiti.
Do I have to uninstall meteobridge or is there a reset procedure to delete camera connection?
When you switch off the AirCam related uploads on "weather network" and "push services" tab,
Meteobridge will no longer grab data from the AirCam.
You can even delete the IP for AirCam on "Network setup" page, then Meteobridge will
even no longer know how to connect to the AirCam at all.
