using port forwarding such as 80 & 22 for other devices
villiewe
Post by villiewe »
"Re: using port forwarding such as meteobridge port 80 & port 22 combo for other devices"
Setting port forwarding to 80 & 22 for meteobridge LAN IP works nicely. Will this also work for remote access of other devices but with other port combos such as 81 & 23?
Re: using port forwarding such as 80 & 22 for other devices
Most routers allow port forwarding including individual mapping of outside port numbers to different inside port numbers.
So you can make Meteobridge ports 80 and 22 avail from the outside as 8080 and 2222, for example.
Doing it that way you can address (from the outside) more than one device listening on port 80 (inside your LAN).
