No data sent for 3 days => crazy min/max
Medor
Post by Medor »
Today, 30/12, I realize I haven't got any data from my meteobridge through HTTP push, and no data is sent to the weather networks, this being since 27/12.
I can connect remotely, and this is what I get in the logs:
Input/output error
logger (30.12.2013 08:57:56): station 0 (Vantage), can't open device /dev/ttyMH:
It had been up for 47 days. I reboot and the "live data" page seems to display normal values, current, min and max. The weather networks and push services start normally.
But on the Wunderground page, the min and max values for today are crazy. Example, for today's outside temp, I get:
Temperature: current: 3.2°C max: - min: 93.3°C avg: -17.8°C
On the PWSweather page, I get:
Hour: 09:05am Temp: 5537.2°C Dew Point: 5537.2°C Humidity: - Winds: 16091.8 kmh N Wind Gusts: - Pressure: 338605.1 mb
- The problem with those impossible values is on the meteohub side, or on those weather servers side ?
- Should I reboot my meteohub once a month, or is there a way to send an alarm in the Push Services when the connection with the station is lost ?
Re: No data sent for 3 days => crazy min/max
When those data is also on the live data tab of Meteobridge, then Meteobridge is doing something wrong. If not, I would like to point to the weather network as I doubt Meteobridge is sending data that differes from what it displays internally. It would help if the weather network could provide the uploaded data set that did produce that kind of extreme data.
But as two networks are impacted I will check the Meteobridge code again, anyway.
