question about meteobridge template
MarKel
Post by MarKel »
i have a question about the variables used in the template for meteobridge
http://www.meteobridge.com/wiki/index.php/Templates
is it possilble to give a meteobridge install a specific name instead of the mac adress ?
i would use this variable (for example: hostname) to identify the correct meteobridge
why i would like this ?
ik would like this to be possible to compare two (or more) meteobridge sensor variables on 1 template
for example
[hostname1] [th0temp-act=F.1:--]°F
[hostname2] [th0temp-act=F.1:--]°F
where hostname1 is for example a weatherstation at home and hostname2 a weatherstation at school/work
can this be done ?
regards,
Marcel
The Netherlands
Re: question about meteobridge template
Meteobridge can only put local data from its own weather station into templates.
So the answer is a clear NO.
