The current meteobridge allows us to adjust our Barometric Pressure before reporting it – which is great!
In a future release of meteobridge can we have the option to also increase/decrease a fixed amount for Temperature and Humidity? This would be helpful for people that have sensors that always read a little high or low.
Maybe +/- x.x degrees F or C in Temperature, and maybe +/- x.x% for Humidity?
Thanks for considering.
Future Upgrade – Adjust Temp & Humidity **solved**
Re: Future Upgrade – Adjustments for Temperature and Humidit
Just a little more info.
I have the AcuLink Bridge, and the way AcuRite makes fixed adjustments to the sensors is via their “my Backyard Weather” Screen. They permit fixed changes to the numbers for Barometric Pressure, Temperature and Humidity. Once you apply the fixed adjustment they send it to their GUI and optionally to WU. Since I’m sending my WU (and other) data out via meteobridge, so I can’t use the AcuRite adjustments.
I use/need the Barometric Pressure adjustment that you provide – thanks. I could also use a fixed changed to my Humidity (I think I need around -2.5% points taken off), and maybe a small tweak to Temperature (maybe about +.3F added to my numbers).
I don’t have any other place where I can make adjustments to my numbers other than the meteobridge, so I’m hoping you can simply add/subtract humidity and temperature adjustments like you do for barometric pressure. It would really help me out.
Re: Future Upgrade – Adjust Temp & Humidity **partially solv
I see you added a feature to adjust temperature, thanks!
I saw you were originally planning to also add an adjustment for humidity, but it didn't make this release. My temperature is off a little (so now I can fix it), but my humidity is off a lot more and I was really hoping you could add an adjustment so I could fix it too. Do you still have plans to add a humidity adjustment too?
humidity is now also included.
Thanks! I'm going to try it out tomorrow.
