Vantage Pro 2 : error connecting USB
Clément
Post by Clément »
I have somme trouble to connect a VP2 to the MeteoBridge.
I get this error message:
wnetd (14.04.2014 14:06:55): process started.
logger (14.04.2014 14:06:57): No historical data loaded.
logger (14.04.2014 14:06:57): data logger (version 4.9y, build 3645) started.
logger (14.04.2014 14:06:58): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.04.2014 14:07:28): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.04.2014 14:07:58): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.04.2014 14:08:28): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.04.2014 14:08:58): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.04.2014 14:09:28): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.04.2014 14:09:58): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.04.2014 14:10:28): connect station 0 (Vantage via USB serial).
logger (14.04.2014 14:10:29): station 0 (Vantage), wakeup sent.
logger (14.04.2014 14:10:29): station 0 (Vantage), internal logger activated.
logger (14.04.2014 14:10:29): station 0 (Vantage), syncing.
logger (14.04.2014 14:10:38): station 0 (Vantage), gettime request sent.
logger (14.04.2014 14:10:48): station 0 (Vantage), gettime request sent.
logger (14.04.2014 14:10:48): station 0 (Vantage), communication blocked because incompatible Davis data logger or console/envoy on weak batteries.
Batteries are ok
FW 1.2
MeteoBridge 2.2
USB hub used
Any ideas?
The datalogger works fine with a PC.
Re: Vantage Pro 2 : error connecting USB
However, your data logger does return invalid data on gettime request. Is time/date set properly on console?.
kjellr
Post by kjellr »
Hi
I got the same error after a couple of days connecting to vantage vue. After a reboot it started working again.
Meteobridge 2.2 build, TL-MR3020, FW 1.4, No hub
