meteobridge w acurite 01025
storm2710
Post by storm2710 »
Can metobridge be configured for both LAN & WLAN MODE to have data go out on both to where i can recieve it on my computer to use it with acurite connect or the reader?
Re: meteobridge w acurite 01025
Meteobridge itself can only be connected via Ethernet or WiFi (not both) to your LAN.
When Meteobridge picks up data from the Aculink, the Aculink must be connected to
the Meteobridge LAN port and the Meteobridge needs to be connected via WiFi to your
network. That way the Aculink is bridged via the Meteobridge to your network and the
Internet and Meteobridge does an inspection of the packets running through to pick up
the included sensor data and making use of it for its own processing as well.
I don't know if this answers your question... However, this is the only way you can
operate the Aculink with Meteobridge.
