This topic is being discussed over in the Meteohub Board, but it has relevance here with MeteoBridge, it's about having these great two peaces of hardware support creating a Data.csv file.
Here is the info for the data.csv format,
http://site.ambientweatherstore.com/vws/vwsmanual.PDF page 52 "7.2 CSV File export", however even though this says "Export" you can import the data.csv file into VWS and use it to display weather data in VWS using the "Station-less" mode. So if meteohub and/or Meteobridge had a push option to create a data.csv file you could use it to display the data collected on a single instances or multiple instances of VWS, also this data.csv file can also be used with WD in station-less mode, possibly other Programs also.
Please consider adding this for a future release. It would be great to View/monitor the data locally with these programs.
There maybe a way to wright a script to do this but I haven't looked into it, anyone up to the task?.
George
http://n1naz.myds.me/weatherweb/index.php Still working on updating the web page.
MeteoBridge - data.csv file
