Troubleshooting help **solved**
beniciawind
Post by beniciawind »
I just got a new cable modem: Xfinity TG862. The Meteobridge, TL-MR3020 will not connect to the internet. The status light just keeps flashing quickly. I have it directly connected with an ethernet cable. It was connecting on the old AT&T modem. Tried reset multiple times, no luck. Any help diagnosing the problem appreciated.
Re: Troubleshooting help
did you try reset to factory defaults (5 blinks reset) as described in getting started section (at the bottom) of Meteorbidge wiki?
It will need a connection via ethernet cable with your router. a pure modem will not work, but I guess you mean a router.
beniciawind
I'll try that. I did it once before but I forgot how. Thanks for the help.
