Raspberry PI - regular Meteohub image 4.9z available
The Raspberry PI image for Meteohub has been reworked and we have a valid starting point now.
Please download and install the version linked here: http://wiki.meteohub.de/Images
You find installation instructions here: http://wiki.meteohub.de/Setup_RPI
When you have installed something prior, please drop that and start over with the image linked above.
Alpha image handed out before will have trouble in doing updates. Correct image has kernel version 3.10.34+ (or newer). If your kernel version (displayed on "System Info" page) is older, please reinstall the SD card image.
Re: Raspberry PI - regular Meteohub image 4.9z available
Please report any bugs on this initial RPI release in this thread.
rainman110
Post by rainman110 »
Is it possible to use the second USB slot on the Raspberry card for the media in lieu of an SD card? Am interested in migrating two old NSLU2's but I just bought two expensive SLC USB sticks that have a lot of life left on them.
sorry, will not work.
dano
Post by dano »
I have successfully migrated data from NSLU2 to new RPI (with licence transfer), but on PRi don`t work Application Data Backup. If you click on Backup in meteohub, display message "Backup to file "/public/meteohub.backup" successfully started.
An entry in the log file will indicate when creation of back file has been completed." but backup file is not created in /public, on NSLU2 this work without problem.
dano
Post by dano »
rainman110 wrote:Is it possible to use the second USB slot on the Raspberry card for the media in lieu of an SD card? Am interested in migrating two old NSLU2's but I just bought two expensive SLC USB sticks that have a lot of life left on them.
If you change SD card, change also System ID !
And a lot of other things will not work, as checks for the SD card are done in several application modules.
adolf
Post by adolf »
Hallo
is there no SSH?
When I get putty I came not in the system.
I wont install WD-Live
Adolf
The meteohub image has a ssh server daemon on board and running. user root, password meteohub.
