Wh1081 cant conect with TL-MR3020
patoar
Post by patoar »
Hi,I can reach the meteobridge trough the WLAN, i used the Hub 2.0: http://www.enxcodex.com/tienda/75-exten ... -azul.html
But i can´t conect to the Wh1081.
This is part of the log in System tab:
logger (20.05.2014 18:19:38): child process received timeout signal (14).
logger (20.05.2014 18:19:38): data logger stopped.
logger (20.05.2014 18:19:38): No historical data loaded.
logger (20.05.2014 18:19:38): data logger (version 4.9w, build 2993) started.
logger (20.05.2014 18:19:39): connect station 0 (WH-1080/3080 via USB HID).
logger (20.05.2014 18:25:09): child process received timeout signal (14).
logger (20.05.2014 18:25:09): disconnect station 0 (WH-1080/3080): exit
logger (20.05.2014 18:25:09): usb port resetted.
logger (20.05.2014 18:25:09): data logger stopped.
logger (20.05.2014 18:25:09): No historical data loaded.
logger (20.05.2014 18:25:09): data logger (version 4.9w, build 2993) started.
logger (20.05.2014 18:25:10): connect station 0 (WH-1080/3080 via USB HID).
I´ve also tried to reinstall with de usb stick, but it was all the same.
Re: Wh1081 cant conect with TL-MR3020
disconnect weather station from AC, USB and take out batteries.
Wait a minute and power on station again. These station tape does hang-up
from time to time and needs a complete power cycle to get operational again.
patoar
Post by patoar »
I've tried everything. I have no luck.
Is it the same wh1081 station that wh1080?
I'll try to change the firmware to v1.4 and not use the hub.
you need the hub with this type of weather station, even, when using FW 1.4
power-cycling the station will do the trick - as explained. WH-1081 is working fine in a few hundred
of other Meteobridge installations, so it must be something with your setup (my first guess) or hardware.
Plase send the MAC of your Meteobridge to "info(at)meteobridge.com", to allow me to login.
patoar
Post by patoar »
Sent.
I´ve noticed that when de hub has not have another usb power plugged the mr3020 ligths dont stop.
