Wh1081 cant conect with TL-MR3020
Posted: Tue May 20, 2014 11:35 pm
Hi,I can reach the meteobridge trough the WLAN, i used the Hub 2.0: http://www.enxcodex.com/tienda/75-exten ... -azul.html
But i can´t conect to the Wh1081.
This is part of the log in System tab:
logger (20.05.2014 18:19:38): child process received timeout signal (14).
logger (20.05.2014 18:19:38): data logger stopped.
logger (20.05.2014 18:19:38): No historical data loaded.
logger (20.05.2014 18:19:38): data logger (version 4.9w, build 2993) started.
logger (20.05.2014 18:19:39): connect station 0 (WH-1080/3080 via USB HID).
logger (20.05.2014 18:25:09): child process received timeout signal (14).
logger (20.05.2014 18:25:09): disconnect station 0 (WH-1080/3080): exit
logger (20.05.2014 18:25:09): usb port resetted.
logger (20.05.2014 18:25:09): data logger stopped.
logger (20.05.2014 18:25:09): No historical data loaded.
logger (20.05.2014 18:25:09): data logger (version 4.9w, build 2993) started.
logger (20.05.2014 18:25:10): connect station 0 (WH-1080/3080 via USB HID).
I´ve also tried to reinstall with de usb stick, but it was all the same.
Thanks!
Thanks!
