Meteostick connection with VP2 console
Hello to everyone. I am a newbie i would like to ask if the meteostick can read data from a VantagePro2 console and not from the iss? I ask this because i m interested about correct inside readings. If the answer is yes could anyone help me doing this???
Re: Meteostick connection with VP2 console
no, the Meteostick reads RF signals and console temp/hum/baro readings are not transferred via RF.
Meteostick provides
1) very accurate baro readings,
2) temp radings with an offset of abot 6 degrees celsius, which Meteobridge sotware compensates and
3) no humidity data, which is filled in for reason of completeness with 30% statically.
Meteostick provides
Ok. I understand that. Just another question. I had some wrong readings in live data. Is there something i can do? Is there a way to check signal from iss?
can you please send me the MAC of your meteobridge?
please send to: info(at)meteobridge.com
