extending adapting clientraw*.setup files
INTRODUCTION:
In another thread I was pointed to the location of the clientraw*.conf files.
They are the template files (with the [] tags) for the generation of the clientraw*.txt files.
I run into problems with the current version of the clientrawhour.txt file and want to modify the generation of that .txt file by replacing [seqmin15_sol0_radiation_wqm@1:-] with [seqmin15_sol0_radiation_wqm@1:0] in all 120 fields containing solar data.
Currently a '-' is used for a non-existent solar sensor value. Correctly from a programmers point of view, but the often used wugraphs fail to process the clientrawhour.txt when containing a - for those values.
Changing the *.conf files in the /home/meteohub/ folder only helps for a short period of time. Maximum to the next modification/save of the WD/MW live setup page. And maybe even the update of a new release will remove the changes made to the *.conf files.
QUESTION:
Is there a location known and user-accesible for the files which are used to generate the clientraw*.conf template files?
I want to
1. change the '-' for non-existenst solar data.
and
2. see if it is possible to extend the number of fields to the latest version of clientraw*.txt
Re: extending adapting clientraw*.setup files
I can change "-" to "0" with the next update as I think it will not put any harm to other users.
The conf file is generated inside the Meteohub code, so no chance or user changes.
YJB
Post by YJB »
I'm probably going to open a can of worms, but is "0" a good default value when there is no radiation readout? I'm not sure WD is using, but I think it will be difficult to differentiate between a -real- "o" and a "no reading "0". I do agree that "-" is causing problems, but that actually applies to all the "-" default values in the the WD files (not only the solar ones).
Ysbrand
YJB wrote:Hi,
Ysbrand
I have to agree with Ysbrand. 0 is a perfectly legal value for a solar sensor.
But the wugraphs are used on multiple websites and those scripts use the clientrawhour.txt to generate the last hour graphs.
Meteohub users who do not have a solar sensor can not use the hour graphs, WD users can.
If someone ask about this in a post on a forum and I see that post, I can send them a very slightly modified script which simply substitutes a zero for the - in the solar fields. But most users will have to skip the hour graphs.
I have to agree with that also. And we do not know where the Metehub versions of clientraw*.txt files are used for.
Indeed for WD-live, in some scripts for realtime ajax values (Saratoga), for the hour graphs in wugraphs.
So changing ALL - values to 0 (WD seems to use a 0 always) can cause more problems than leaving everything as is.
Changing the - to 0 for the solar fields in clientrawhour.txt is a minor change and will hopefully not lead to unexpected side-effects. If so Boris will probably be kind enough to revert the code back to the old situation.
