FTP Camera upload duplicating images **solved**
viennaxmas
Post by viennaxmas »
I have a problem with the FTP Camera Upload...
here is the setup:
Aircam 1.2 using "External Picture" to get image (Problem with initializing Aircam).
Upload to Wunderground every 5 minutes
Camera FTP Upload server every 2 minutes
When looking through the images on the FTP server, I did notice , that the image only refreshes on the 5 minute wunderground interval. It does seem that the Camera FTP Upload does not pull a new image but rather uses the image received during the WunderGround pull.
This means that I end up with 2 or 3 identical pictures on the FTP server (different time stamp in file name). The images do have a date / time overlay, so I can easily see that there are duplicates.
Any idea why?
Re: FTP Camera upload duplicating images
Good finding! I just changed that in the code. When you reboot the Meteobridge fixed code should apply.
viennaxmas
Re: FTP Camera upload duplicating images **solved**
Thanks for the quick fix - this seems to work now :D
