The SD card can record 4GB meteohub, why?
Napajedlaci.cz
Post by Napajedlaci.cz »
I bought a new SD card Kingston SDHC class 4 gigabytes (4). Roadkill software in 98% error lists. I tried it maybe 4 times and unfortunately still the same. The card I went back to the store and bought the same rather new. Again ... 98% and end: (
I have inserted the SD card into another program and it lists this.
All I'm trying to Win8.
Napajedlaci.cz is very good weather station in Czech republic neer town Zlin.
Re: The SD card can record 4GB meteohub, why?
Napajedlaci.cz wrote:I bought a new SD card Kingston SDHC class 4 gigabytes (4). Roadkill software in 98% error lists. I tried it maybe 4 times and unfortunately still the same. The card I went back to the store and bought the same rather new. Again ... 98% and end: (
The 4gb is not exact.
And every brand has a slightly different size.
No problem when you format the card and write files to it. All space is then available and the miniscule differences between brands do not bother you.
But writing a diskimage needs a card which is at least as big as the original from which the image was made.
So if orginal sd card from the diskimage you are trying to copy is slightly bigger than your new card, no way it will fit on that SD card.
You should try another brand.
