rsync - daemon not running (Solution)
gm4jjj
Post by gm4jjj »
As I did not seem to be able to create a backup in the /public folder, I thought I would try rsync instead.
I am not sure if the rsync daemon is running because when I try I get:
./rsync -uav --info=progress2 rsync://root@meteohub/data /Users/david/Desktop/Meteohubdata
rsync: getaddrinfo: meteohub 873: nodename nor servname provided, or not known
rsync error: error in socket IO (code 10) at clientserver.c(128) [Receiver=3.1.1]
Thanks in advance for any advice.
Edit: Got it working -
1. I started the daemon on meteohub via ssh
Rsync --daemon
2.
My error:
I needed to specify the IP address of "meteohub"
./rsync -uav --info=progress2 rsync://root@192.168.x.x/data /Users/david/Desktop/Meteohubdata
David
gm4jjj
Re: rsync - daemon not running (Solution)
Post by gm4jjj »
In order to get the rsync daemon to start at bootup I had to edit /etc/default/rsync and change the line
RSYNC_ENABLE=false
to
RSYNC_ENABLE=true
thanks, will change that with next update.
Flens63
Post by Flens63 »
the setting still gets up false
