OpenWeatherMap upload
jachym
Post by jachym »
I've recently added upload to OpenWeatherMap. The data is sent correctly, but for some reason, the station is sending OK only temperature, humidity, precipitation and pressure. The wind speed is shown as "undefined", any ideas? I think there is probably a problem in the POST command integrated into meteobridge, they might have changed the syntax of it.
Re: OpenWeatherMap upload
I checked and it works fine with my rig.
jachym
Post by jachym »
Thats weird...
Obviously there is no problem with the station itself, I am using meteobridge to send data to several networks and for example here at WU:
http://www.wunderground.com/personal-we ... IJIHOMOR28
It works OK, so the wind is measured correctly.
However, if you look at openweathermap and display the map with stations and look at Brno, my station is called Brno-meteopage.com and you see the wind is not there and if you click on more details it shows as undefined. Even though I am using purely the scripts for sending to networks via meteobridge. My station is WH-1080.
