What would the syntax be to set an email alert when rain exceeds 1 inch per hour?
Rainfall per hour
Re: Rainfall per hour
I have no clue about that answer
I think the "Raise" event you want is:
That says "when the rainfall rate per hour equals or exceeds 1 inch, send the alert."
[rain0rate-hmax=in:0] - 1- wsnoordbergum
I'm using a alarm for rain (Twitter)
Raise is: ([rain0rate-act.1:--] > 0.5) && (rain0total-sum10.1:--] >0.4)
Clear is: [rain0rate-act.1] = 0
I'm using mm instead of inches.
For rain exceeding 1" you could use:
Raise: ([rain0total-sum60.in:--] > 1)
Clear: ([rain0total-sum60.in:--] = 0)
Use a one time alarm otherwise you will get a lot of e-mails.
If your meteobridge is set to handle inches you can delete the "in" converter and replace it with 2, this means two decimals, fi. 1.24" of rain.
I think this will work.
WsNoordbergum
WsNoordbergum
