RFXtrx433E USB Transceiver decoding issue
This is intended for discussion and information about the rfxcom receiver module
martijnho
Post by martijnho »
Hello, I have a issue with a new RFXCOM receiver. Adding the receiver to meteohub was not the problem all the sensors are found and receiving signals.
For testing this new receiver, I have connected the sensors on two stations the original WMRS200 and the new RFXcom receiver.
And expected that the two stations are receiving and decoding the same values from the sensors.
Only there are a few things that are not working correctly. All the sensors are giving a low battery icon. (that is not the case)
and the rain sensor is decoding wrong values multiple times bigger than the values received by the original WMRMS receiver.
Now the question: is the new “RFXtrx433E” transceiver already fully compatible with meteohub?
jmontamat
Re: RFXtrx433E USB Transceiver decoding issue
Post by jmontamat »
Happens to me the same thing, does not seem to have solutions for dealing.
JM
